what do you use when going mirrorless?
Old May 5, 2006 | 12:16 AM
EngineNoO9's Avatar
exactly what it says. I have some bolts that work and are the identical size of the mirror ones and same thread but the head of them are a lil too small... are people just running a bolt through and not caring about any rub on the plastics it might do since it'd be concealed by the mirror base anyways?
Old May 5, 2006 | 05:23 AM
Carnage's Avatar
Carnage
Re: what do you use when going mirrorless?
Try looking around on the web for motorcycle mirror block off plates. I know they make them for other bikes but not sure about ours. Usually they're a nice little plate that's the same shape as the stock mirror. Another idea if you don't plan on putting regular mirrors back on and you plan on riding in an area that requires them, there are mirrors that are just little nubs, not functional but I guess they keep the man off your case.
Old May 5, 2006 | 05:33 AM
EngineNoO9's Avatar
don't need mirrors here. I was gonna ride around for a few without them until I get a new left mirror base which is busted... I think my dealer sells some plates that kind've look like block offs... From pics though it always kind've looked like people just stuck a bolt through...
Old May 5, 2006 | 06:36 AM
superhawk22's Avatar
Nothing. Be careful without mirrors though, it's sometimes hard to turn enough to see on the right side.
Old May 5, 2006 | 07:05 AM
EngineNoO9's Avatar
wait you use nothing to hold the fairings to the brackets? That's all I'm asking
Old May 5, 2006 | 07:40 AM
Yep, I just take the mirrors off and leave the holes there. I've done this every time I go to the track which has been 8 or 10 times so far with no problems. The bolts for the wind screen hold that on so I didn't see a need for anything else.
Old May 5, 2006 | 08:02 AM
marmaladedad's Avatar
Hmm?
Zip ties.
Besides duct tape, the most useful tool you could carry.
If you really want, find a piece of plastic you can cut/dremel to shape, along with two holes in the middle for the screws to use as a block off plate.
Old May 5, 2006 | 09:40 AM
Sgt Rock's Avatar
Guys, if you go to Autozone they sell the push plugs for about a buck. They are a perfect fit for the mirror holes.
Old May 5, 2006 | 09:55 AM
Carnage's Avatar
Carnage
I like your thinking marmaladeboy. Fabrictation is one of my personal favorites. You make it how you want it, you get the satisfaction of knowing you made it, and it's unique. So unless you just suck at making things fabrication is then better way to go. Oh yeah it's cheaper too.
Old May 5, 2006 | 11:37 AM
EngineNoO9's Avatar
i just used the bolts I had with some washers on top which made the fit better and look pretty good. it'll take a lil getting used to but ima try it out for a few
Old May 5, 2006 | 12:41 PM
EngineNoO9's Avatar
links to pics
http://filebox.vt.edu/users/jomuller/P1010066.JPG
http://filebox.vt.edu/users/jomuller/P1010067.JPG
http://filebox.vt.edu/users/jomuller/P1010068.JPG
http://filebox.vt.edu/users/jomuller/P1010069.JPG
Old May 5, 2006 | 01:22 PM
Hmm?
Oh ****, I forgot about that one. I actually did that too, the whole washer/screw thing once. But zip ties are much easier to cut off, and I'm lazy like that.
You know you're supposed to wipe the bike down after washing it, right?
Old May 5, 2006 | 03:33 PM
That's the new wet look.
Old May 5, 2006 | 03:43 PM
Hmm?
I've heard about that one. It's supposed to have a girl with a white t-shirt on, too, right?
Old May 5, 2006 | 03:49 PM
Well that is the best part of it apparently he forgot that part.
Old May 5, 2006 | 07:47 PM
Hmm?
Hey, as long as the picture of the pink chaps Cowboy doesn't show up again, I'm a happy camper.
Old May 5, 2006 | 08:43 PM
Apparently you missed this. https://www.superhawkforum.com/viewtopic.php?t=2765
Old May 5, 2006 | 08:52 PM
Hmm?
Oh, no, I saw that thread. And I saw the reaction-posts, so I knew not to click on it. Tricky tricky.
Crashrat
Aug 25, 2010 09:20 PM
roisman
Mar 2, 2007 03:01 PM
Randman
Feb 28, 2007 07:17 AM
Erion_squid
Jun 27, 2006 12:50 PM
Hawkrider
Jun 25, 2006 05:23 PM
