What am I dealing with?
2 Attachment(s)
I'm new to the forum...should've joined a couple of weeks ago when I made my purchase but I haven't had a chance. I apologize if I missed this in a search. I'm about to replace the frame of a 2002 Superhawk I bought (it has a salvage title due to be stolen). I have done work on several bikes I've owned so I know each time is a new adventure and new problems ;). My main concern are the forks. I've researched but haven't found any info about this fork adjustment mod. If you can tell from the pics and know feel free to chime in. The guy I purchased it from was a little out of it and didn't have much information. Thanks for the help.
looks like preload adjusters.
not much too talk about really. what are your concerns? |
Those add-ons just allow easy tool free adjustment of the spring preload. If you know how to properly set sag, once set there really is no need to be adjusting.
Thanks for the replies. I thought it was for a quicker way to adjust the springs. I just didn't want to start disassembly and be surprised. I've found that out the hard way with other bikes I've owned with random mods. While I'm asking is the Shindy steering damper really needed/useful along with the Coerce fork brace for everyday riding? I'm deciding what parts to keep and what parts to possibly remove and sell.
Fork brace = YES! Damper is a matter of opinion typically. If your properly set-up, sag and geometry wise, you really don't need one.
It IS a quicker way to adjust the springs. That's what preload is. It is the constant pressure (load) on the springs. Looks like aftermarket clip on handle bars too but that is not of much concern.
It looks like your forks are slid up in the triples. That's a bad thing on the VTR (most bikes in fact) so you will want to lower those back down where they belong.
Welcome! |
(Post 381752)
Welcome! |
No its not better or worse. Personal preference.
I had a big long paragraph typed up twice on how you can adjust rake any way you want, and i referenced sport rider articles proclaiming dofferent ways to adjust suspension, but my phone deleted both the paragraphs... Twice. So, i give up. Here's a good link: Art & Science: Fun With Geometry | Sport Rider There is nothing wrong with pulling the forks up in thr triple clamps, though Sport Rider found 7mm to be too high on the track, as they began scraping hard parts at that point. Personal preference. Ride your bike. Take notes of settings. Make one change. Write down the change. Rode your bike. Note how change affected bike. Repeat. James |
I agree James, ride it and see first. Just beware of corner clearance if you go too low on the whole thing with compressed suspension.
It becomes really cloudy when talking in general about changes. Here are some points to consider:
- A stock VTR will be helped by raising the rear 20mm (that's about a 6mm shim at the shock). - A VTR with properly setup suspension is best with a 3mm shim (approximately +10mm ride height) - It is not advisable to lower the front by moving the forks in the triples in either case. The last point goes against what you will commonly find stated. That is because people go by feel and not actual data. Dropping the front cases instability which makes the rider's brain think they are pushing really hard. Raising the front back up allows you to push harder and generates better handling performance. But what about turn in? I'm sure someone is already loading up their ammo on that one. Again, this is a much misunderstood concept. With the correct springs and valving you will get good turn in performance. In fact better than lowering the geometry. If you want your bike to handle well address the source of the problem. It is amazing how often people miss that! Adjusting geometry to fix poor damper performance is not very successful. |
(Post 381763)
- A stock VTR will be helped by raising the rear 20mm (that's about a 6mm shim at the shock). - A VTR with properly setup suspension is best with a 3mm shim (approximately +10mm ride height) - It is not advisable to lower the front by moving the forks in the triples in either case. The last point goes against what you will commonly find stated. That is because people go by feel and not actual data. Dropping the front cases instability which makes the rider's brain think they are pushing really hard. Raising the front back up allows you to push harder and generates better handling performance. But what about turn in? I'm sure someone is already loading up their ammo on that one. Again, this is a much misunderstood concept. With the correct springs and valving you will get good turn in performance. In fact better than lowering the geometry. If you want your bike to handle well address the source of the problem. It is amazing how often people miss that! Adjusting geometry to fix poor damper performance is not very successful. As to turn in that could answer a small problem on my bike. Will try lifting the front back up then. Happy to take advise from experts on suspension. Better make a block to go under my stand though, thing already tries to fall over. Lift the front will make it worse. |
(Post 381763)
I recently raised the front end on the 848 and it made it a different bike to ride.
Has an adjustable link in the rear, raised that and the it wanted to fall into the corners, so raised the front and was a big improvement. Compared to other bikes in the cave the Storm is the most neutral in the handling department, however there have been many changes to the Storm as well. |
Originally Posted by theconundrum
(Post 381695)
Sorry about this conundrum, I'll try to get it back on topic. Welcome to SHF! |
(Post 381775)
Please keep replies related to the OP questions. This is getting a bit off track....
