wewt! package just came with the latest mod to my superhawk
Old Jun 28, 2006 | 11:41 AM
EngineNoO9's Avatar
guess what it is. :P
here's my bike:
Hint: it came in a 18"x18"x12" box
Marmaladeboy and denmah aren't allowed to guess because they know
Old Jun 28, 2006 | 11:56 AM
mirrors with turn signals?
Old Jun 28, 2006 | 12:01 PM
EngineNoO9's Avatar
gross no. I have mirrors but took them off. They're going back on here before heading home. is gonna be weird to have them again
Old Jun 28, 2006 | 12:08 PM
seattlesucks's Avatar
seattlesucks
Aftermarket brake calipers? Flushmount turn signals? Frame sliders?
Old Jun 28, 2006 | 12:23 PM
miniature rocket booster? laser death ray? small chemical toilet?
Old Jun 28, 2006 | 12:31 PM
Vincent's Avatar
Vincent
Seat
Old Jun 28, 2006 | 12:42 PM
an aftermarket shock?
Old Jun 28, 2006 | 12:56 PM
A Team's Avatar
A Team
where did you get those frame sliders and how mutch?
Old Jun 28, 2006 | 01:50 PM
twitcher's Avatar
twitcher
those stands look pretty shiney...
Old Jun 28, 2006 | 01:55 PM
Chilly996's Avatar
Chilly996 is on a distinguished road
Yeah, the stands. Does the rear one still have protective shipping wrap on it or did you put that on?
Old Jun 28, 2006 | 02:12 PM
EngineNoO9's Avatar
DING DING!! thanks to marmaladeboy for it.
Fox twin clicker
I actually just dropped it off at Go-race.com to be rebuilt, revalved, new spring. Gonna cost about $250 or so all said and done. I might get the guy to do the rest of the work on my bike too. Like put the shock on. And he said he'd set all the settings for me if he did and tell me how to use it. Also asked about my front end and said at some point if I do lots of track days that he does traction dynamics kit which is way better then the racetech stuff. Now 1 question I ask is he's gonna set it up for me at 220lbs. But my goal weight is around 200 (yeah yeah I'm on a diet). Should I say set it up for 200lbs instead or what? I'm worried that if it's setup for more that when I'm lighter I'll be screwed...
and what were you asking about the stands? they're from checkered flag motorsports. like $80 a set I think. Great stands though the rear is designed for spools. So I flipped them over and puts some rags on to protect my swingarm. They're powdercoated black too
Old Jun 28, 2006 | 02:50 PM
BirdofParadise's Avatar
BirdofParadise is an unknown quantity at this point
here's my bike:
Sooooooo....what did the updated pic of your bike have to do with the question???
Still has the stock shock. :-)
It got me thinking and looking (like "Where is Waldo").
Oh and nice job on the bike....looks nice.
Old Jun 28, 2006 | 02:52 PM
EngineNoO9's Avatar
pic is posted so you don't guess stupid things that I already own.... that pic is about a month old now. rear shock won't go on for about another month or two
Old Jun 28, 2006 | 02:53 PM
superhawk22's Avatar
I would lean toward being too stiff then too soft. If I were you I'd probably go somewhere in the middle, if you're 220 and want to be 200 set it up for 210. That way you aren't bouncing all over the place when you get up to speed. You're planning on doing track days on it right? You don't want it too soft when you're out there and well we never really know how well the diet will work do we. (I speak from the heart there) As far as the stands I got those T-rex stands on ebay for $99 shipped and they do both spooled and non-spooled swingarms. :wink: Good luck and good riding!
Old Jun 28, 2006 | 02:56 PM
EngineNoO9's Avatar
well... idealy I'd be a solid 180-190.... I'm more expecting 200 without much trouble... and yeah I've been there done that with losing weight. heh. I used to wrestle so it's shouldn't be too hard getting back into shape with a diet + good cardio. Honestly I think setting up for 200 should be fine... But granted I'm still kind've a noob at this and is why I'm asking for advice on the matter. if it's set for 220 and I put it on the lowest dampening setting I guess it'd work... or even 210... I dunno. the whole adjustable shock and easily adjustable preload (even moreso then stock) is new to me....
Old Jun 28, 2006 | 03:01 PM
You're better off a little too stiff then too soft but not overly stiff either or it will skip on you. Too soft you'll get a pogo effect and high speed wobble which is THE LAST thing you want at speed in a full lean. I forgot you're still a youngin so the weight won't be as much an issue as it is for me. The older you get the harder to get it off, wha wha wha.
Old Jun 28, 2006 | 03:05 PM
EngineNoO9's Avatar
so... 210 then? or maybe even slightly lower.... ?
Old Jun 28, 2006 | 03:09 PM
If you're serious about the 180-190 then go for 200 that way you leave yourself some wiggle room. The springs usually have a little bit of room for example a spring is set up for someone 200 to 210 or 190-200.
Old Jun 28, 2006 | 03:15 PM
EngineNoO9's Avatar
gotcha. I'm gonna call tomorrow and say setup for 200. that's what my .95kg springs in the front are setup for. Plus I'm not buying a full suit until I'm in better shape cause well I'd be throwing money down the toilet
Old Jun 28, 2006 | 03:20 PM
Are you going for a 1pc or 2?
Old Jun 28, 2006 | 03:25 PM
Silly me.
I figured it as in here is my bike...can you see what I added that came in a 18x...box.
Good luck with the shock set up.
Old Jun 28, 2006 | 03:31 PM
EngineNoO9's Avatar
I'm going for a 1 piece. 2 pieces seem silly to me
Old Jun 28, 2006 | 03:32 PM
If it's for track use only I agree.
Old Jun 28, 2006 | 03:38 PM
EngineNoO9's Avatar
even for weekend use 2 pieces seem silly... granted if I had one I'd wear that instead of a 1 piece depending on the situation/ride... 1 piece will do me fine for awhile
Old Jun 28, 2006 | 11:39 PM
marmaladedad's Avatar
Hmm?
A 2piece is SO much easier to get in and out of on the hot, sweaty days when you just stick to the liner of your suit (unless you wear the long-sleeved under-armour-type liner). I love my 1piece for the fit and comfort.
Nice shock. Best of luck with it!
Old Jun 29, 2006 | 12:59 AM
I just got an 18x...box today.
Some thing like yours No9 but with a yellow spring.
Thanks Marm!
Old Jun 29, 2006 | 07:50 AM
It's also nice to be able to take the jacket off for lunch or going to the bathroom or just hanging out waiting for the next session. Underarmour type stuff is a must IMO.
Old Jun 29, 2006 | 09:08 AM
A Team's Avatar
A Team
How about those frame sliders? I keep asking because the ones I see, you have to modify the fairing. Yours look like you didn't have to.
Old Jun 29, 2006 | 09:11 AM
Here's a couple of links that will help you out.:wink: https://www.superhawkforum.com/forum...=frame+sliders
Old Jun 29, 2006 | 09:26 AM
Hmm?
Thanks Marm!
Awesome BoP! Had me sweating bullets there since I thought it hadn't arrived yet.
