Tires & front disks
I need new front ' rear tires as well as new brake disks for the front on my 98 superbawk. Any suggestions? Front disks are warped.
Where on the globe are you at ? This will help.
No offence but how do you know your rotors are warped, as opposed to the stock brake hose pulsating? The reason I ask is warped rotors is not a high failure Item.
If however you've pulled the rotors and put them on a surface plate and checked for gaps then you're right and I apologize. |
Apparently...warped disks are a common fault with these bikes! I just found that out after buying a 2006 model with only 5000 miles on it. Luckily the seller replaced them before buying! Aftermarket ones are good..Honda prices are out of the question! and what's the point, they going to warp anyway!!!
OEM front disks wore below tolerances at 50,000, replaced again with Honda disks - 60 thousand and counting still going strong….
Some folk mistake 'warped' disks for seized up floating bobbins.. Just put a nut and bolt through each one and spin them a bit to free them up. |
I have a set of brake tech 320 iron rotors that are excellent. However some slight damage from water. I was in Ca and visited with Jeff Gears @ "brake tech" last week. He is planing on running more disc for the VTR but in stock 298mm size. We talked about RC51 or CBR1000 iron 320mm replacements with an adaptor.
Any one interested????? Not cheap but you get what you pay for., Frank |
Originally Posted by Dave Airola
(Post 363101)
BTW I warped my stock rotors. Actualy it was very easy to do. If you like this bike and want to upgrade change the brakes. Master, calipers,rotors!!! & lines . You'll love this bike! Good luck Frank
Originally Posted by frankoborg
(Post 364574)
So, after owning the bike for a few weeks, you know what the common faults are better than half a dozen guys that are on their tenth year or more of owning one... Good for you... And since you have that much knowledge, start working on the way you deliver that knowledge to the rest of the world... It can benefit from a little fine tuning... I have swapped warped brake discs for exactly two reasons... One, they plain wore out... And two, they where warped because I left the disc lock in there... I have however helped about a dozen local riders with sticking rivets for the floating discs, glazed patched due to holding the brake on while properly hot, and a number of other things that make people think the discs are warped, while they are in fact not... |
(Post 364579)
If you check the run out on your rotors with a dail indicator and they are beyond spec, then you have warped rotors. If you haven't used a dail indicator you probably don't know for sure that your rotors are warped. You just know you have a problem.
Maybe he actually does know what he's talking about and actually has warped rotors. Lots of people sittin' on high horses around here.
On my prior superhawk I replaced rotors with EBC pro-lites, decent price and nice rotors. Here's an example: EBC Pro-Lite Front Brake Rotor - Cruiser Motorcycle - Motorcycle Superstore |
Originally Posted by VTRDarren
(Post 364623)
(Post 363101)
Anyone interested in 320mm iron rotors? Brake Tech will do a group buy qty 10 sets. I'll post prices tomorrow .
Originally Posted by Lefin102
(Post 364651)
darren, check my other post "brake tech 320mm rotors"
(Post 364662)
I rechecked the old rotors I thought were warped. They are not warped!!!! My bad. They are so discolored they wouldn’t clean up at all. I tried to dress them and the color change form heat is there to stay. I guess they got a little hot.
| All times are GMT -7. The time now is 04:18 AM. |
