Throttle Cable Housing Mod
Thought I'd share how I got a lot of clearance btwn the throttle cable housing and the fairing. I got Two Brothers racing clip-ons, and this helped me get them as low and in towards the tank as possible . I was able to re-position the cable housing so that the brake lever is btwn the two cable tubes. First I took off the brake lever. Then without taking apart the throttle assembly, I was able to slide it off the bar end, then I re-routed it from inside of the right fork tube to be on the outside of the fork tube. This allowed me extra slack in the cables to rotate the housing upward. I then slid it back on the bar end, and centered it around the brake lever. Aslo, with my bars so close in and down so much, I found it more comfortable to ride and operate both the controls having re-positioned them at an exaggerated angle, twisted more towards the ground, than normal. so my wrists are not bent up. If anyone is interested, I got more pics, but am still learning how to post.....
