raise front fork tubes - how high?
Old Jun 4, 2006 | 11:08 PM
V6Bob's Avatar
V6Bob is on a distinguished road
Question raise front fork tubes - how high?
How high do people suggest raising the front fork tubes for best handling? Ground clearance is not an issue in this case.
How high can you raise them without risking a bump clearance problem between the front fender and the bike?.
Old Jun 4, 2006 | 11:12 PM
denmah's Avatar
denmah
do you mean lowering the bike by dropping the triples farther down on the forks?
if thats what your asking the answer is, whatever your riding style and area will allow, as in if your in a very flat area and you dont wheely alot you can probably drop it pretty low and never touch. youll just have to drop it and try.
as for changing height for handling... if they are stock tubes nothing will really help i would say, just modifying front forks with heavier weight oil, better springs etc is the only way to go for handling.
Old Jun 4, 2006 | 11:23 PM
marmaladedad's Avatar
Hmm?
Start with 5mm. If you like it, try a little bit more. The bike will be less stable the more you pull the forks up through the triples.
Old Jun 5, 2006 | 06:40 AM
I was told by VTR guru Roger Ditchfield (REvolution Racing) NOT to raise the forks or shim the rear shock if you are running the stock fork set-up (ie. stock springs and valving) as the bike can become dangerously unstable. A word to the wise as they say
Mikstr
Old Jun 5, 2006 | 07:49 PM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
I'll second that. Tankslappers suck, and with the stock setup and a shimmed rear, mine headshaked a couple times, then tossed me in a ditch back in '04. 15wt oil, properly set up preload on both ends, no shim, and a steering damper have cured the headshake completely. Now if I just sprung for new front springs, I'd be golden.
Old Jun 5, 2006 | 07:56 PM
superhawk22's Avatar
I never did anything to the stock setup so I don't know what the results would be. That being said I do have GSXR forks on it now which are about 1/2" (what's that about 5mm?), shorter and have had no headshake at all even on the track going as fast as I could. I don't know if the stiffer components have anything to do with it being more stable though.
Old Jun 6, 2006 | 04:31 AM
denmah's Avatar
denmah
i would say being that they are GSXR forks they are just going to perform better than stock SH forks
Old Jun 6, 2006 | 05:23 AM
I had my forks re-done (added Race Tech springs, drilled cartridge body and filled with 7.5 wt oil as per specs provided by Roger at REv. Racing) then lowered them @ 8mm. I have since added a fork brace also. I added a 4.7 mm shim to lift the rear end too. All told , the bike carves now and is quite stable. AS I got a good deal on a steering damper, it now ha one of those too. It's allllllllllllll good !
Mikstr
Old Jun 6, 2006 | 08:13 AM
Well you're right about that they are awesome, but I don't know if that's why it's more stable than what Galaxieman said.
hook_ed
May 20, 2014 02:46 PM
merckid
Feb 24, 2013 03:01 PM
tauntis
Dec 28, 2010 07:31 PM
redman
Oct 19, 2007 10:13 PM
redman
Oct 17, 2007 01:55 PM
