radiator demensions
Kai Ju did the under seat rad and says it doesn't give hot *** even in Southern Cal. There were pictures of his bike on the forum and you might do a key word search to see if you can turn anything up. It was pretty cool! Good luck!
Oh ****! A VTX radiatior has to be huge by comparison. The Superhawk can be misleading when it comes to size. We set this shot up one afternoon at our shop and I didn't realize until I looked at it on my monitor that the VFR was the biggest, the CBR was in the middle and the most powerful bike (VTR) was the smallest.
I've been watching this thread daily and I'm rooting for you.
One thing in your favor is that V twins seem to be happier with smaller radiators than I-4's.
A couple of things to keep in mind:
Air never does what you expect it or hope to. (My side intakes are almost useless, but at least they look cool )
It's a lot harder to push air through the radiator than to suck it through. If you decide to push, make sure that you use fanblades desiged to do so.
I had actually fabbed up some pressurized side intakes that came through the opening under the VFR tank and dumped air on top of the radiator.
Didn't make a difference even though I had the radiator completely sealed off inside the tailsection to eliminate losses.............
I've also noticed, due to a levitating back pack, that the area behind the rider is a low pressure area and will eventually modify the tail section to take advantage of that. I am concerned about heat to my back though.
Who knows, your tailsection may just be the perfect solution and work without a hitch.
If there is anything you want to know about my bike, just ask.
Kai Ju
well your vtr being the smallest is kinda funny, cause my vtr is gonna look tiny compared to a semi stock one.
Im planning on air entering up under the tail, going through the radiator, up and out through the top of the tail via the low pressure area.
The problem is that under the tail is also a low pressure area. I may have to re route the air coming into the radiator from somewhere else.
Im using a puller fan, or 2 if I can fit them.
vtrlvr
Feb 12, 2007 05:16 AM
custom, demensions, dimensions, ducati, honda, ju, kai, measurement, monster, radiator, raditor, superhawk, underseat, vfr, vtx
