Race Tech Fork Springs
Old May 6, 2010 | 12:06 PM
Seattle_SuperHawk's Avatar
WWTDD
OK i am 270lb 6'3" superhawk rider. I need to upgrade my fork springs, but ordering them online i want to get it right the first time...... Any idea what size ??? And how difficult are they to install ?? Your input is appreciated
Old May 6, 2010 | 12:11 PM
zmaniv's Avatar
Remove the top cap and the spring comes out. replace and you are done.
The problem that you are going to face is the damping rates for a spring this strong is not going to work well. You should really consider upgrading the valves as well.
Old May 6, 2010 | 12:44 PM
98ILVTR's Avatar
Old May 6, 2010 | 12:54 PM
WWTDD
Cool, Springs sound easy enough, how about the Valves ? If anyone is parting with .90 or larger springs and valves, let me know.....thanks
Old May 6, 2010 | 01:30 PM
jbaxx's Avatar
Honducati
Minor detail, but make sure the front end is properly supported before removing the caps.
Also with the heavier spring, you could try heavier fork oil as well.
Old May 6, 2010 | 02:33 PM
Karbon's Avatar
Karbon is on a distinguished road
1st download the factory manual from the SH knowledge base. Study the exploded fork diagrams
On the RT website there should be a spring rate calculator which recommends the proper spring rate.
I suggest getting the front end of the bike off the ground by a jack or a lift and removing the fairings and forks completely. Pulling the fairings give you better access to the components.
The .9 springs i have on my bike are longer than the OEM forks springs, so you have to cut the spacers to get the preffered preload or zero preload if you're going to achieve a stock lenght spacer+spring combo. I also had to adjust the air gap to compensate for the volume of oil the RT springs displace. About 5 mm more than stock.
At 270 lbs you might want to looks into getting the proper spring for your rear shock, as changing the front will undoubtely highlight any shortcomings of the rear suspension.
I got lucky at 210-200 lb fully geared I was still in the ballpark of the EOM rear shock spring.
Old May 6, 2010 | 04:06 PM
bjorn toulouse's Avatar
Destructive Tester
First, as mentioned, buy/download the SuperHawk shop manual.
Second, call RaceTech or Traxxion Dynamics or whoever and talk with a service rep., they will take the info you need to get you the right set up the first time.
Rex
Old May 6, 2010 | 04:12 PM
residentg's Avatar
.90 are too light for your weight, the spacers need to be 72mm
Old May 6, 2010 | 05:49 PM
uchi's Avatar
im running a spring setup for a 250 pound guy, im 257 right now ad theyre halfway in, so far so good
Old May 6, 2010 | 06:28 PM
superbeater's Avatar
Jamie Daugherty can set you up with Sonic springs and spacers cut for your weight for about $85 shipped. Probably the bestdeal out there. Search the forum or google.
blubyu
Jul 3, 2009 08:38 AM
inderocker
Jun 16, 2009 10:46 AM
HawkRider98
Sep 8, 2008 09:27 AM
FL02SupaHawk996
Dec 21, 2007 04:49 AM
102dals
Nov 27, 2006 02:46 PM
