Quick question regarding fork spacing
Hey guys, can anybody tell me the measurement between the forks, center-to-center and/or the width of the front fender across its top between the forks?
As a means to "de-link" the VFR's linked braking system, I'm using Superhawk fork lowers on my '01 VFR (keeping the VFR fork uppers and internals--albeit rebuilt with Race Tech gold valves--and triples), and the fender mounts on the Superhawk fork lowers/sliders don't match up with the holes in the VFR fender. I can fab up some adapter plates easily enough, but it'd be nice if the fork spacing on the Superhawk and VFR were the same and I could just fit a Superhawk fender directly to the Superhawk fork lowers/sliders. Thanks. |
I measured the distance between the centres of the rebound adjusters on my VTR, albeit in semi-darkness, and came up with 193 mm. I hope that helps.
Thanks, Comedo, that's just the info I needed :thumbsup:.
Unfortunately, the VFR looks to be closer to 125mm, so no easy-out for me. Ah, well, brackets it is. Thanks again. |
Dear South,
Are you sure that 125 mm. is the centre to centre distance? Isn't the nominal width of your VFR's front tire 120 mm? What I measured was the distance between the fork centres taken from the top of the forks. |
Well, if you really want to put the screws to me, I'd have to say it's more like 124 mm, center-to-center at the fork-top preload adjusters ;) (no rebound or compression damping adjusters on the VFR). If for no other reason, I believe the extra width between the forks on the VFR is to accomodate the linked braking system: oversize front calipers, fork-mounted secondary MC, delay valve, and extra plumbing and associated clutter. Just allows a little more clearance to keep that stuff off the rim.
Originally Posted by south
(Post 311393)
(Post 311395)
how do you get 124 or 125 mm to be "extra width" compared to 193 mm?!
| All times are GMT -7. The time now is 07:33 AM. |
