SuperHawk Forum
-   -   Mysterious fluid (https://www.superhawkforum.com/forums/general-discussion-30/mysterious-fluid-31447/)
pchrist Dec 8, 2013 04:06 PM
Mysterious fluid
2 Attachment(s)
Attachment 23092
Attachment 23093
Anyone know what this is and how to fix?
E.Marquez Dec 8, 2013 04:12 PM
Ahhh, it appears to be a mystery, more so as there is no picture if you added one.
Wicky Dec 8, 2013 04:42 PM
Probably prostate - see about getting a TURP...
VTR1000F Dec 8, 2013 04:46 PM
Is it yellow?
pchrist Dec 8, 2013 05:45 PM
Fixed added photos
VTR1000F Dec 8, 2013 06:31 PM
Looks like coolant. Water/antifreeze.
Looks like you've got some leaking and running over your stator cover there. The fix depends on where it's leaking from. Can you find the leak?
sjscicluna Dec 8, 2013 07:04 PM
coolant from overflow bottle check tightness of all hose clamps and check your radiator cap mine was buggered and letting water over flow in to bottle and out of hose.
NHSH Dec 8, 2013 08:01 PM
Coolant for sure, you can tell from the separation lines around, the more purified water penetrated to the concrete floor and the heavier consistency oily substance in the coolant stays on top.
j shizzy wizzy Dec 11, 2013 04:51 PM
If it happened during extreme cold, you probably have a crack in your reservoir somewhere, plastic shrinks in the cold and opens the gap. Happened to me.
CaryDG Dec 11, 2013 10:05 PM
You might also check the coolant hose connections at the carbs. Had this happen after a re-jet when I failed to get the clamp on the carb heater hose.
pchrist Dec 15, 2013 01:54 PM
2 Attachment(s)
yes it has been very very cold here lately. Single Digits
Had the head replaced last year so could be something from that.
Did a little more looking on it and this is what i found you can see where the liguid starts to freeze and turn to icle.
Is this somehting i need to look into fixing now or later?
This summer after i got the bike back i almost had an overheat issue due to low antifreeze. Wondering where to start looking or if it should wait to warmer weather? I added distilled water after and it ran fine the next few times i rode with no issues. I assumed some antifreeze leaked out with the head replacement and just didn't get back in. So what do you think??? Looking for advice.....
Attachment 23084
Attachment 23085
pchrist Feb 11, 2014 06:13 AM
Should I add some distilled water to it and see if it will leak more and where from so I can figure out where it's leaking and how to fix it? Don't want to be laid up this summer from this!
comedo Feb 11, 2014 07:38 AM
Identifying the source of leaks can be difficult but that icicle is a big help in pointing you in the right direction.
I'd infer that the bike is not stored in a heated garage. It would be safer to add coolant rather that pure distilled water when temperatures are so low.
pchrist Feb 11, 2014 08:19 AM
going to look closer tonight. What recommendation is there for adding coolant? Should I put in a mix or just straight antifreeze??? Been so busy haven't had time for anything!!!!
E.Marquez Feb 11, 2014 09:15 AM
premix your coolant (or add some ready to use like Pro Honda HP Coolant 50/50 Premix or Maxima Coolanol )
Appletonhawk Feb 11, 2014 10:11 AM
Had a similar issue recently with random coolant on the floor under the bike. Couldn't find a leak anywhere and with the cold temps here near zero for almost two months now, I talk to a guy at the Honda dealer that told me they used silicone hoses on our bikes which will under extreme cold tend to sep or leak a little bit which is what we are assuming happened in my case because I have since run the bike and no issues at all. No leaks or overheat issues.
E.Marquez Feb 11, 2014 11:31 AM
Not on my bike or any other I have worked on....
Appletonhawk Feb 11, 2014 12:07 PM
Just what guy at the dealer told me. Not sure if true.
E.Marquez Feb 11, 2014 01:56 PM
Fair enough....
So anyone that knows the hoses are OEM on their SH..have Silicon hoses installed from the factory? ( I am pretty darn sure the answer will be no... which might indicate you should be wary of other "facts" that dealer tells you)
spladle160 Feb 11, 2014 06:37 PM
Mine will lea a bit from the hose running from the thermostat housing to the rear cylinder (I think) occasionally and randomly. I've tightened the clamps but it still does it, I don't really care enough to replace the hoses with nice aftermarket silicone ones which can leak when cold. If you really want to find the leak take some really cheap spray on deoderant that leaves a white powder and spray it in the are you suspect the leak.
E.Marquez Feb 11, 2014 08:00 PM
Originally Posted by spladle160 (Post 368371)
Mine will lea a bit from the hose running from the thermostat housing to the rear cylinder (I think) occasionally and randomly. I've tightened the clamps but it still does it, I don't really care enough to replace the hoses with nice aftermarket silicone ones which can leak when cold. If you really want to find the leak take some really cheap spray on deodorant that leaves a white powder and spray it in the are you suspect the leak.
May I suggest spray on dry foot powder in place of deodorant .. it leave more "powder" for a trail to appear in.. works well for oil leaks as well.
pchrist Feb 13, 2014 09:01 AM
Bike is tucked away pretty tight for the winter tough to find where the leak is and pull any plastics off of it. Was going to add more coolant and see if I still have the leak. Temps finally have gone to the + side of the temp guage. Is there any coolant that can be picked up at the local hardware store or other store?
hawxter996 Feb 13, 2014 03:01 PM
http://i188.photobucket.com/albums/z...psmk45cent.jpg
http://i188.photobucket.com/albums/z...psd1nvo6uo.jpg
this 1st pic what are we looking at?
what section of the bike.
I cant quite make it out.
pchrist Feb 13, 2014 05:58 PM
It is right in behind the choke
CruxGNZ Feb 13, 2014 06:17 PM
Where is it leaking in the second pick? Almost looks like a drip forming under the top fitting.
pchrist Feb 14, 2014 05:18 AM
1 Attachment(s)
Ok took this pic last night you can see a drip to the back behind the block where the choke is. Is this the link of where coolant flows between the carbs???
Attachment 22939
7moore7 Feb 14, 2014 07:17 AM
That's the thermostat- inside is a valve that opens up when the bike gets warm enough to allow the coolant to flow through the motor. The bottom (temp sensor) fastener does not appear to be tightened all the way. It almost looks like it's dripping on the choke cable and running down that.
That's black over spray on the connectors right? Or is it something else?
hawxter996 Feb 14, 2014 08:02 AM
http://i188.photobucket.com/albums/z...psjsau5rqc.jpg
looks like a line is missing on thermostat housing!
look at the top!
eta.......may not be used.
pchrist Feb 14, 2014 08:34 AM
Yes the black is overspray. The drip is actually back in the back on a hose coming out behind the thermostat housing.
7moore7 Feb 14, 2014 09:28 AM
look at the top!
Just a decoy plug. Not as often does it work it's magic like PVLIR
