Moriwaki Rearsets
Hi everyone I just received my MW rearset today, my question is where do i find doweling tool in order to take swingarm bolt off? thanks in advance for any answer, infos, advice. James
I thought the swingarm was just a regular nut and long bolt beneath the plastic cap - no special tools other than a long socket necessary.
Originally Posted by cliby
(Post 43639)
VTR Bandit, thank you 4 your respo, yes it is but only 1 problem have no one to hold the bike when rear tire and swingarm off. Anyone give me a hand (just kidding)
Well, I guess it was easier for me since I was tearing the whole bike down, so I had the whole exhaust off. My first time, I just had the bike supported on a cinter block. Second time, I bought an ATV jack from Harbor Freight and it was a lot nicer to be able to lift and lower the whole engine.
It is possible to use just a plain jack, and rig up some 2x4s to bypass the headers, but that is a little trouble than its worth I think. |
1 Attachment(s)
Originally Posted by trinity012
(Post 43735)
Thanks for infos ,sir.Nice bike anyway what are you working on w/SH now?
I have afew more stuffs before the whole bike completed, rejet, wait for ceramic coat to finish (I should have done whole complete end to end black) rearsets, replace w/vortex clip on handle bar,grips,pazzo lever, rear brake line, M R front rear fender-belly pan.) it just too cold this year to tinker w/the bike now 29* out side |
I'm working on race-prepping mine. It won't be as pretty at the end of this summer, I'm pretty sure :( I'm trying to find some way to mill out some custom rearsets I've got designed, and then aside from that all I've gotta do is safety-wire the bike and do some fiberglass work to replace the lights with number plates. Got some sliders on their way, because it's pretty much guaranteed that I'm going to crash, several times :P
I did the same thing, hang the bike from the rear passenger mounts just enough to light the rear. I used a wooden dowel rod the same width as the bolt and forced it through to push the bolt out. This kept everthing in line and allowed me to do it alone. Hope this helps.
It helps me changing my resets this weekend along with shock, rear huger, undertail, tire just like a different bike.
| All times are GMT -7. The time now is 11:34 PM. |
