Mod pics as promised
Old Apr 24, 2008 | 09:05 AM
StoneJrW's Avatar
StoneJrW is on a distinguished road
Pics as promised. Pipes, SS lines, Mirror extenders and front view. The lower fairing was off when I took the pics.
Old Apr 24, 2008 | 09:06 AM
StoneJrW's Avatar
More Pics. Vfr Bars, Bars touching on left turn, Bars touching on right turn and clip on at the base. The clip ons appear to sit flush but I will cut off the tab just in case. The bars dont touch a little bit.........they touch a lot. The pics are not fully turned right or left and they already touch.
Old Apr 24, 2008 | 09:16 AM
Dusty B's Avatar
nOOb
Dusty B is on a distinguished road
Looks good man! Been meaning to pick up a set of those mirror extenders myself....
Btw, what rear turn signals are those? Are they the "arrow" ones I've been seeing on ebay? I was curious about them.
Old Apr 24, 2008 | 11:29 AM
StoneJrW's Avatar
I believe so. I put them on last year. They are made by lockhart Phyllips. I didnt buy them on ebay I bought them at a local bike shop.
Old Apr 24, 2008 | 12:08 PM
superbling's Avatar
Try <deleted due to brain fart>.
Old Apr 24, 2008 | 01:06 PM
Um... bling? how? Mine seem to be attached to the frame you know...
A workable solution thoo would be to turn the clipons a bit towards you, should give a bit more wiggle room... could also add a couple of washers under the plastic at the top mount...
Old Apr 24, 2008 | 01:32 PM
superbling's Avatar
Umm...... yeah. Opps, I had a big brain fart and for some reason was thinking of them mounted UNDER the top bridge. DOH!!
+1 on shimming the fairing out with washers (I used rubber grommets) at the mirror stalks. Also judging from the pics, it looks like you can move the switchgear around a bit for more room but will probably need to re-drill the locking pin holes.
No need to remove those locking tabs either. I don't see them causing any problems in the pics.
finepooch
Jun 8, 2014 06:26 AM
Sep 25, 2011 12:06 PM
blight
Sep 28, 2008 07:25 AM
andy9743
Sep 6, 2007 12:21 PM
superhawk22
Jan 19, 2007 07:52 PM
