Let's all post a pic of our bikes.
Please include photo, year, mileage and how long you have owned it and City your from.
1998 Super Hawk, 22,000 miles, 4 months
KC, MO
KC, MO
<a href="http://s934.photobucket.com/user/dveneman/media/SH1.jpg.html" target="_blank"><img src="http://i934.photobucket.com/albums/ad186/dveneman/SH1.jpg" border="0" alt=" photo SH1.jpg"/></a>
Yellow Superhawks! Can't pass up a chance to post photo of bike, again. We have to post yellow hawk photos here since no one else will look at them.
1999, had it for one year . Central CA. "low" miles.
Yeah, 66 year old spode on a sportbike
Say, anyone know if those pipes are fiberglass filled and have to be repacked? At 26k that thing is sure loud.
Txs in advance...
I bought it two months ago with 22000Km so about half in miles on it. Looked new. Didnt do my CCT's
By the way in all of my posts I never said My name is rob. I like beer and Redstorm is my bike. Redstorm likes Top gun and long cruises.
Yes repack those pipes snowdirt, its not a fun job but you have to do it.
So SSS bike has CBR1000rr front end, Mario Nava bodywork, VFR swingarm, apex riser bars. Maybe 7k miles.
Daily bike is also a 98 but with a 05 motor. Penske shock on both, givi triple rack, CBR600rr digital dash with fuel guage. Oakley 3 grips on both, vista cruise, in dash voltmeter, under seat trunk big enuff to hold tools, plug kit, lithium jumper, and compressor for tires. Eastern beaver high voltage headlight wires. Brake flasher with COB lights in givi topcase red reflectors. Corbin seat, triboseat cover. Heli bars. Larger "race" radiators, custom delrin sliders on bar ends, frame and to protect pipes. Around 20k on motor, many more on bike.
Li
1998 manufactured in March of 1997 but I've owned since new and maintained and modified entirely by myself with 105,000+ miles not km.
All original components are still on the bike except those I've replaced or modified to improve performance, safety and and/or reliability except of course for consumable parts like tires, drive chain, sprockets, brake pads, etc but the clutch and rear wheel bearings are still OEM original parts, and it still gets 33 to 35 miles per gallon with fantastic handling, comfort and reliability, knock on plastic.
BTW, it now sports EBC wave brake rotors front & rear
Motorcycle Care & Feeding, "Only Right Is Right"
I alternate my rides between my VTR and new FJ-09 now but have two spare VTR engines waiting for a chance but the original refuses to retire. A vacuum leak down test on it this spring indicated it was well less than 5%. As soon as the engine was wore-in at about 4,000 miles I started using auto spec Mobil 1 10W-40 (or was it 5W-50?) but when they changed the formula wear packages I went to Shell Rotella T6 full synthetic. I also use Purolator's PL14610 oil filter (now their "BOSS" version due to insufficient concave engine - filter interface).
Before the FJ-09, I also rode a 81 Kawasaki GPZ550D1 that I sold with 63,000 miles, a 84 Honda VF500 with 50,000, 88 Honda NT650 with 68,000, 72 Kawi H2 Mach IV with only 23,000 but I still have my 77 Yamaha RD400. Before that it was all Matchless and AJS singles and twins, and before that BSA, Norton, Ariel, BMW, a 1975 MV Agusta 750S America (for 2 weeks before I turned it over for then "Big Money") and other marques.
My philosophy and ethic regarding keeping two wheeled and winged conveyances on which you risk life and limb is reflected in my first post-degree employer's company motto (Convair), "Only Right Is Right".
BTW, "Clip-Ons" are Dan Moto 3-D with longer stainless steel socket head cap screws, askew washers and Nylock nuts. I ran similar Tommaselli 3-axis bars for many years before but needed more rise due to a neck injury in a bicycle crash (caused by another bicyclist!), and before that for a few years, Helibars. Grips are ProGrip gels safety wired, and I like the NEP throttle lock in conjunction with the rear carburetor spring disconnected and a customized Cramp Buster.
Skokie I am always amazed at how similar our bikes are set up. Right down to the cruise control, top box, added dash gauges, body protection etc.
Do you have your rear indicator lights on always as running lights? I have mirror leds and fairing leds as running lights in the front. I mounted red leds into the rear turn signal lenses as running lights.
One difference is how clean your bike is. I ride daily so in the rain often. My bike wishes it were cleaner.
I run the Lockhart Phillips Type 3 three-wire turn signal / running lights with the clear lenses up front but gutted the internals and installed Custom LED's insert with the amber and white LEDs. I then installed the VTR OEM front turn signal / running lights in the rear and ran a third wire that is powered by an ignition-on circuit but run some very bright LED "bulbs" I bought on Ebay. I also wired up my own low-draw turn signal flasher. So the the rears are turns and running lights, although amber lens rear running light are technically a DOT no-no. I also installed very bright amber LED strips on the passenger peg brackets for excellent side visibility. Rear braking conspicuity could always be improved but for now I have two red LED strips mounted above and below the license plate (on a re-purposed dealer license plate surround frame) tied into the brake light circuit. I used to run a 65/70W halogen bulb (of course with a beefed-up wire gauge wise Eastern Beaver headlight battery-direct wiring kit) but this year installed one of Cyclops excellent new version LED headlight units, with the high beam on a Kisan Pathblazer P115W-H3 headlight modulator. I highly recommend headlight modulators!
I still have not tried installing either one of the hand guard sets you recommended but given the protection afforded by the FJ-09 which has the OEM heated grips, a barn door of a Givi wind screen with a added adjustable top spoiler and had guards for a KTM Adventurer in lieu of the Yamaha OEM Transformer hand guards, the FJ-09 will be my designated cold weather assault weapon. I did make a small summer shield for the FJ, as the OEM shield is abominable, as the Givi shield is oppressively hot much above 80 degrees.
Cleanliness is next to Godliness, and the action often catches problems in the bud.
How many miles on your VTR now?
skokievtr, I noticed this "Before that it was all Matchless and AJS singles and twins". I may want to communicate with you a little. I have a 1956 AJS twin that was my dads. He bought it new in 1956 when he got out of the navy. With a couple of small exceptions it is complete but real rough. Very low miles but sat outside in southern California so there is rust. He has been gone for over 10 years now but I want to restore it to be like it was the day he brought it home. I hope to start on it this winter.
Are you in OK?
Are you in OK?
Are you in OK?
Are you in OK?
