Dyno time!
Finally got a chance to get her on the dyno! How did the old girl stack up against yours?
https://cimg1.ibsrv.net/gimg/www.sup...3d560090ca.png |
I think you're down a bit on powa. https://cimg0.ibsrv.net/gimg/www.sup...99b14133b.jpeg |
(Post 406800)
OE flywheel. I did carb stuff about 10 years ago and I can't remember what's in there. Before carb work/K&N, it did 108 on the dyno. Before this run, I installed the JF fuel screws and cleaned my K&N, reset TPS. Bike ran perfectly all that time before but now it's unhappy below 4 and my a/f plot shows a bit lean. So some tweaks are in order.
(Post 406802)
Just over 30,000 miles. Maybe it’s cuz it’s red. :evillaugh: |
I use one of them Eriks flywheels ...LOL
Flywheel weight does not effect Dyno numbers as far as false or different readings. I have done back to back pulls , same day, same part of the day with and without light weight flywheel ...numbers were consistent with only the normal error range anticipated Dyno to Dyno results comparing are all but useless. Machine, calibration, operator, altitude, weather all effect the outcome. |
Yep, I do agree. That being said, in '08 bone stock with just a slip-on:
https://www.superhawkforum.com/forum...n-dynoscan.jpg 108ish on a 2 up completely different dyno, different software, yadda yadda. https://www.superhawkforum.com/forum...03376small.jpg Then one month ago, my VTR was ran on Koups dyno. I did some carb tweaks not long after the run in '08 and changed to low mount D&D. Only 2 hp difference which seems very realistic. |
(Post 406806)
(Post 406804)
You've found the before - now find the after...
Id like to make a few pulls on the local dyno here but the guy wanted 100 bucks for 3 pulls.
Ive done car dynos for 30 bucks for 3 runs before! is 100 bucks about what others are paying for bike pulls? |
Originally Posted by Floyd
(Post 406817)
Originally Posted by Wicky
(Post 406812)
Guess I will have to go more drastic... |
(Post 406800)
Originally Posted by PoorMansDucati
(Post 406820)
I thought I was at the after! LOL Like most of you, I have been plugging away for the past few years, K/N, jetting, TPS, velocity stacks, Flo commander, R/R, Jack Flash fuel screws, manual cct's, the list goes on.
Guess I will have to go more drastic... PS Here's a variety of dyno runs from the UK VTR forum > https://www.vtr1000.org/phpBB3/viewforum.php?f=36 |
(Post 406817)
Ive done car dynos for 30 bucks for 3 runs before! is 100 bucks about what others are paying for bike pulls? The shop occasionally has done Dyno night in conjunction with bike night..it was billed as a HP shoot off, but stopped doing it due to liability. even with owners signing a form and having to hand write in their upper RPM limit they were willing to let it rev to.. A few blown up bikes, few broken bits of plastic as we hunted for the hook up locations, or later lost fasteners they claimed we did not put back or tighten and hurt feelings made it unpopular with the shop owner. Dyno time at that shop is $250, but its not just a few pulls, its all the adjustments that can be made on your bike in that session. Power commander guys get the best bang for the buck on the deal, carbed guys the worst. Dyno operator has been know to break up the session in two parts though, a run, send bike and owner home to tinker, and another session later |
You are definitely missing some HP and the torque output shouldn't drop. Do you have the AF plot? If I have to guess the AF is too lean and the carbs need more juice->bigger jets.
This is mine with Dinojet/K&N (old version) https://cimg8.ibsrv.net/gimg/www.sup...169ff9b4c9.jpg |
My dyno time was $5. The local Ducati/Kawasaki/Suzuki dealer has an open house once a year and the dyno is free. They charge $5 for the print out with torque and a/f.
| All times are GMT -7. The time now is 08:20 AM. |
