Does it wheelie in second without the clutch?
Old Apr 30, 2005 | 05:26 PM
AZZKIKER's Avatar
I am 220 pounds, obese in other words and I ride a 98 SH. It power wheelies in 1st butI cannot get it up in 2nd without the clutch. Is your bike the same? Is it weight related? My friends has a TLR that wheelies in second no problem. But he is about 50 pounds lighter.
Old May 1, 2005 | 10:08 PM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
I've got mine down 1 in the front (15t sprocket) and I haven't figured out sit-downs in second yet. It's right up with the clutch, but I can't figure it out on throttle. FYI, I'm 6'0" 200lbs, so I'm in your weight class as opposed to your TL riding buddy's. It will lift in 2nd if you're doing stand-up wheelies, I let a friend ride mine and watched him do it. I can't do stand-ups due to a buggered knee from my wreck last summer (I probably could, but don't trust the knee completely yet), but like I said, I have seen them done. Maybe our OZ VTR_Stunter can shed some light on this subject...
-Jim
Old May 2, 2005 | 05:16 AM
AZZKIKER's Avatar
Re: Does it wheelie in second without the clutch?
Yeah, I tried man. On second and gunning the gas while the suspension is compressed. Nothing happens, it doesn't even lift a little bit. It goes right up in first, but not in second. It is frustrating to see the TLr that weighs a lot more and goes up so much easier.
What do the stunters have to say about that?
Old May 2, 2005 | 08:39 AM
superbling's Avatar
With a 15t, I get unintentional 2nd gear wheelies after coming down in 1st and shifting (I'm pathetic at wheelies and don't try to shift in the air). But that doesn't count does it since I'm using the clutch during the shift?
Old May 2, 2005 | 09:25 AM
VTRDarren's Avatar
VTRDarren
the TLR is also rated around 118+hp, that might have something to do with it as well. I've had no luck in 2nd but, as others have found, my friend can manage it with a little boune-then sit back down-approach.
Old May 2, 2005 | 10:13 AM
thegreep's Avatar
thegreep
I have had mine come just enough off the ground to lose steering in 2nd under hard acceleration, and I'm about 210lb. Though, Ive never had it feel like it was going to really come up like mad. I kind of like the controllability of it as I am not into the crazy stuff (well, other than speed. . .)
Old May 3, 2005 | 03:31 PM
faz's Avatar
faz
faz
I can't even keep it up in first gear!
of course, not the bike's fault.... I don't know how to wheelie!
Old May 3, 2005 | 03:49 PM
NOrrTH's Avatar
I can get it up, just cant keep it up. I blame my anti-depressant medication.
Old May 3, 2005 | 04:23 PM
Monomaster's Avatar
Monomaster
You won't power it up in 2nd unless you move your *** to the very back of the seat & give her a bit of a bounce.
Mines 1 tooth down on the front & won't lift under power either.
Clutch it...its better for the bike as well!
Old May 3, 2005 | 04:59 PM
ClevelandSuperhawkRumble's Avatar
lol.... sure sure , clutches arent THAT expensive... lol .
Old May 3, 2005 | 05:41 PM
Philipian Ricer,
what landing strips do you ride on man! sheesh... i cant get a straightaway longer than 2 miles without a cop. lol. unless im ridin in amish country... but though horse pies on the road will mess ya up. like a banana peel.
Old May 3, 2005 | 07:28 PM
Thumper's Avatar
Clutch it, doesn't hurt the clutch at all if you are light with it.
I can pull mine up in 2nd and 3rd with just the slightest pull of the clutch. You of course are running about 70mph and around 5k rpm best i recall when doing this is third (not that i care or look at the tach, it's all about the feel of the engine pull and power). I rarely get obove 10k as the dyno runs pretty much show the power drops off at 9.5k anyway.
1st gear wheelies are wickedly bad on the head bearings, 2nd and 3rd gear wheelies allow for a softer power landing and easier on the head bearings.
If you go her jetting at the preferred air/fuel mixture ratio she will come up in third. At least mine will
Ohhhh..... Stock gearing, original spockets and chain
Old May 3, 2005 | 09:17 PM
take it from a sports fan and cleveland local .... this **** can be dangerous... see link ----> http://www.wkyc.com/news/news_fullstory.asp?id=34316
and to think the Browns may have gone somewhere with him. . .
Old May 3, 2005 | 09:24 PM
have you guys considered putting a steering damper on our SH ? i mean ive seen videos of IL4's tankslappin and crashin. kinda scary.
Old May 4, 2005 | 12:36 AM
Monomaster's Avatar
Monomaster
Cheaper than gearboxes, which is what is under strain with power wheelies (mono's)...
$250 against $1500 for a gearbox...
Old May 4, 2005 | 05:38 AM
Galaxieman's Avatar
Yep.
Tankslappers suck. Here's a tip: get your suspension set up correctly (Front preload HIGH, rear preload LOW, due to soft front springs) or the thing being nose down will cause headshake issues. I figured this one out the hard way...
-Jim
Edit:
Note: SHs are not known to be prone to tankslappers, and now that I've got my suspension set correctly, I don't think it's much of an issue, but then again, I'm paranoid and sure as hell don't want to wreck again due to headshake...
Old May 4, 2005 | 04:47 PM
Monomaster's Avatar
Monomaster
Nice Scotts steering damper...did you have to do any mods to get it to fit or was it model specific!
I thought the steering head type were for dirt bikes...
I like it, well done!
Old May 4, 2005 | 08:16 PM
Galaxieman's Avatar
Bolted right up. Bought it and the bike specific adapter from kneedraggers.com. FedEx lost a piece of my shipment, and when I called Kneedraggers they had another one overnighted. Great customer service. Well, there's my plug for the day...
-Jim
Edit: see site here: http://www.kneedraggers.com/details/22-SCOTTS-6
Old May 5, 2005 | 09:32 PM
VTRBeefa's Avatar
VTRBeefa
I have had a few tanks slappers in the past on various different bikes, but wasnt until I had one a little while back on my new storm that I honestly felt totally out of control of the bike and so close to being spat big time.
It only needs to happen once for you to realise the merits of a damper.
I have had the forks redone since the slapper and think this may have had something to do with it... if it even comes close to happening again a damper will be on its way.....
Scenario is identical to everyone else who has written about it on the storm... 2nd or 3rd gear under full acceleration and hitting a small bump... gets that sphincter puckerin for sure !!
Old May 12, 2005 | 04:37 AM
98SuperHawk's Avatar
98SuperHawk
Back to the wheelie question......It can wheelie 2nd without clutch, as I found out on tuesday night. I went to race another bike beside me on a roll in 2nd, brapp right off the ground without me pulling up or any clutch work. It actually took me by surprise twice. It probably helps when your around 155lbs....
Old May 12, 2005 | 10:07 AM
NOrrTH's Avatar
Monday night I was riding with nine others, two of them VTR's. We were on the freeway doing 100km's when the guy on the yellow one pops up to his balance point and takes it up to 140km's before setting the front down.
Holy **** I didn't know our bikes could do that. So I talked to him at our stop and all he'd done to the motor was slip on's and a stage 1.
Old May 19, 2005 | 09:01 AM
bryantmvtr's Avatar
bryantmvtr
two provisions on what i am about to say: 1)im under 200lbs, and 2)i have my 98 vtr geared a crap load lower... 1 down in front and 5 up in back.... anyway, i can just pull the throttle back in first or second and the front end comes up... in third, i actually have to put a lot of effort into it. pretty fun, except that all the oil goes to the back cylinder, so i burn oil as im up in a wheelie for a while. im wondering if anybody knows of a oil sender unit so i can get oil to goto the front cylinder, instead of just sitting in the back of the engine. thanks!
Old May 24, 2005 | 10:59 AM
bryantmvtr's Avatar
bryantmvtr
agreed on the stand up.stand up wheelies are much easier to control. if you get in trouble, just collapse your legs, lean forward, tap the back brake, close the throttle. granted, i have my bike geared one lower in front, and 5 up in back, but i can pull the bike up at about 3.5 grand in 1st, 2nd or 3rd, no clutch. be careful out there. wheelies arent for kids!
BlackHawk996
Nov 19, 2008 12:03 AM
bow135106
Jun 16, 2006 12:29 PM
denmah
May 8, 2006 06:15 AM
Dreded
Apr 13, 2006 03:53 PM
mikecronis
Mar 21, 2006 02:39 PM
