Coolant Bottle Question
Old 03-03-2014, 07:29 AM
thedeatons's Avatar
Hey guys... Looking for some advice on this.
Just noticed a drop of icky colored fluid under the bike. Traced it back up to the lower nipple of the coolant reservoir, where a drip is suspended at the connection of the hose and the plastic nipple.
Not sure if I just need to tighten everything/get a new hose, or if there is a crack.
#1 Has anyone found a nicer looking coolant bottle to swap from another bike? Something low profile, and easily hidden? (not necessarily aluminum)
#2 Is the location/height of the stock coolant bottle important in its functioning properly?
James
thedeatons is offline
Old 03-03-2014, 08:23 AM
Yes and no. As long as it's below the radiator cap, it's location and size are highly flexible.
Mine is hanging out where the right radiator used to be (it's the coffee cup looking thing), and it is piped all the way from the rear of the tail where the fill cap is currently and it works just fine.
7moore7 is offline
Old 03-03-2014, 02:09 PM
macdee's Avatar
macdee is on a distinguished road
a couple of men over here have used the honda hrc coolant bottle
Genuine HRC Honda Racing Overflow Expansion Catch Tank Radiator Water Bottle | eBay
macdee is offline
Old 03-03-2014, 02:20 PM
thedeatons's Avatar
Where are they mounting that? Does anyone have any "installed" pics?
James
Old 03-03-2014, 03:29 PM
macdee's Avatar
James
macdee is offline
Old 03-03-2014, 03:39 PM
thedeatons's Avatar
Not really into that setup. Too exposed. I would like it hidden....
James
Old 03-05-2014, 08:34 PM
thedeatons's Avatar
Anyone ever thought about using a front brake reservoir, maybe mounted inside the frame on the right side, near the carbs by the original bottle?
Could easily put a barb in the lid for a vent.
Could mount it on the frame, kinda like the choke **** on the left side, mounted with one bolt...
Any thoughts about this?
James
Old 03-06-2014, 07:40 AM
I think Kai Ju used a VTR250 Interceptor coolant tank in the stock location when he did his undertail radiator. Essentially it's a similar height and width as the stock one, but about 2/3 the length. Maybe something like that would give you enough room to fiddle with the carbs. It's not going to give you that "see through the frame" look, but if it fits it would be well hidden.
I would be hesitant about something as small as a brake reservoir. I'm pretty sure there is more expansion going on then that between hot and cold...
7moore7 is offline
Old 03-06-2014, 05:39 PM
thedeatons's Avatar
Good response! That's the info i need to know, how much coolant is really moving through the bottle.
Anyone have anymore info on the vtr250 coolant bottle? I will try pm'ing that member.
James
Old 03-06-2014, 09:36 PM
Upland111's Avatar
vtr 250 coolant bottle in eBay Motors | eBay
Upland111 is offline
Old 03-06-2014, 10:02 PM
I was just looking at this. You're right, there is limited room to get at the fuel screws, especially for guys like me with rather large hands. That VTR250 coolant bottle is a nice option. Cheap too!
Another option that I was thinking of doing, was cutting the stock bottle down and plastic welding it back together.
Just had another thought, what about mounting the stock bottle between the fairing and frame? Not sure if there is enough room, if any at all. Will have to play around with that.
CruxGNZ is offline
Old 03-06-2014, 10:25 PM
Upland111's Avatar
I am working on a solution, will post up when completed. Likely there are no two solutions that will utilize the same material or location. Just another reason why making it your own is half the fun.
Old 03-06-2014, 11:15 PM
Just took another quick look, and there is enough room to attach a coolant bottle (cylinder or rectangle) onto the end of the right side radiator. I think I'm going to weld up a tank and go this route. As with Upland, I'll post pictures too.
CruxGNZ is offline
Old 03-07-2014, 06:00 AM
Kai Ju may not be that responsive... he sold his VTR two years ago and build the bike like 7 years ago so I'm not sure if he's still around.
I'm not even 100% sure it was him that pointed out the coolant tank to me. I bought the bottle but the way I routed my hoses I couldn't get it to fit (a stock hose routing would fit I think).
Companies build a margin of safety into their overflow bottle, but I doubt using something less than 1/10th the size like a brake reservoir is big enough. Maybe something 1/3 the size...
7moore7 is offline
Old 03-07-2014, 06:03 AM
thedeatons's Avatar
The trouble with the vtr250 bottle option is they are a discontinued part, and they were made in 1990. That means they are 10 years older than our superhawk bottles that are cracking. Seems like they will be even more prone to failure...
It would be great if someone found an OEM looking version of a coolant bottle, aluminum or plastic, and we could find a "hiding place" for it.
James
Old 03-07-2014, 06:23 AM
James
Whisky flask?
Or how about one of these? All they need is for the entrance hose to go to the bottom, or connect to something that does, and some kind of vent.
Amazon.com: Nalgene Wide Mouth Rectangular Bottle (64-Ounce): Sports & Outdoors Amazon.com: Nalgene Wide Mouth Rectangular Bottle (64-Ounce): Sports & Outdoors
7moore7 is offline
Old 03-07-2014, 07:58 AM
thedeatons's Avatar
That Nagale bottle is a pretty cool option. We use those for camping and they have never leaked.
I think I'm holding out for something that looks a little more OEM Honda-ish...
Keep the ideas coming, this is a great thread!
James
Old 03-07-2014, 09:10 AM
Why on earth would you want it to look OEM? Those Honda penny pinching regulation following engineers wouldn't know cool if it rode up to them on a dry clutch and slapped them with a straight exhaust! Go against the grain! Whisky flask! Use some aluminum beer can as a shim for your BMW! If you have the gumption to see the beauty of materials as they are and not as some overseas professional labeled them, that is!
7moore7 is offline
Old 03-07-2014, 10:22 AM
thedeatons's Avatar
I don't drink... So the beer can and whiskey flask idea is out.
I'm open to some other awesome ideas though, like aluminum.
I want it to be nearly invisible. Like ya know it's there, but it blends in so well it doesn't catch your eye.
James
Old 03-07-2014, 10:35 AM
https://www.google.com/search?q=alum...m+water+bottle
https://www.google.com/search?q=alum...um+fuel+bottle
https://www.google.com/search?q=alum...tle+motorcycle
https://www.google.com/search?q=alum...oolant+bottle+
Dynasty 280 Series - TIG Welder - GTAW - Miller Welding
E.Marquez is offline
Old 03-07-2014, 11:16 AM
You could use an apple juice flask then, or a soda can! Or make a small black hole so the event horizon hides it! Or wrap in in grey digital camo!
7moore7 is offline
Old 03-07-2014, 11:23 AM
The Varadero's coolant bottle hides under the radiator... maybe that will hide enough? It's kind of hard to tell how much the VTR's fairing would cover this:
Didn't find any for sale, though
7moore7 is offline
Old 03-07-2014, 11:44 AM
How about these OEM ones James? They all seem small enough to hide behind the fairing. I'm thinking of picking up the Ruckus bottle (would save me some time from making a custom one)
-'09 Honda Ruckus
-'92-'96 BMW K1100RS
-Marauder VZ800
CruxGNZ is offline
Old 03-07-2014, 12:31 PM
thedeatons's Avatar
Those are all great options....
James
Old 03-07-2014, 05:20 PM
And the winner is...*drum roll*...
Whatchya goin' with James?
CruxGNZ is offline
Old 03-07-2014, 05:25 PM
thedeatons's Avatar
I dunno... I can't think anymore today.
Old 03-08-2014, 07:32 AM
thedeatons's Avatar
Crux you should buy one of those so i can see how well it works
It's kinda shocking to think no one has done this before...
James
Old 03-08-2014, 12:14 PM
Looking at the space available again (next to the right side radiator, between the fairing & frame seems to be the easiest spot) and looking at the three that I posted above, I think that the BMW coolant bottle will work better than the one off the Ruckus. The BMW bottle seems to be thinner and hold more fluid than the Ruckus.
Riding season is almost here in these parts. Somebody on a crotch rocket was on HWY 94 yesterday (45F).
Let me look around a bit more to make sure this is the best option I can come up with. If it is, I'll buy the BMW one on Monday
CruxGNZ is offline
Old 03-08-2014, 03:14 PM
No one's made adjustable pilot screws before
You look at the streetfighter forums and those guys put coolant bottles all over the place.
7moore7 is offline
Old 03-20-2014, 02:02 PM
Well guys, after looking around, I found the best option was the BMW coolant bottle that I linked to in post #23. I just bought it earlier today for 14 bucks, which is not bad at all
It should be here sometime next week. I'll take a couple pictures and show the installation.
CruxGNZ is offline
Quick Reply: Coolant Bottle Question
