ALUMINUM 101 (how to polish without sanding)
Well I have been lurking and reading for some time now, and feel that I need to contribute some now as a payback for all the help I have recieved from this forum.
The information I have is passed from another , I found it to be the holy grail when it comes to aluminum ,I hope you all will as well.... In order to polish any part of aluminum one must first remove any protective coating that has been applied to it. The prossess to keep all aluminum durable is usually anodizing and it provides a hard coating over the part that protects it and makes it resistant to abuse.... Often refered to as clear coating it is this layer of protection that most people sand off in multiple steps from coarse to fine.....very time consuming and labor intensive ... Well no more my friends !!! follow my instructions that follow for yourself , you will be amazed how easy this can be. 1 . mask off all parts with masking tape and newspaper that have paint or plastic or finish that you like. use 3 or 4 layers and take your time here it will be worth it. The only thing exposed should be the areas you want polished. 2 . Painted surfaces must be removed with paint remover such as jasc (follow there directions on the back) 3 . now go to the grocery store and buy a can of EASY-OFF OVEN CLEANER the lemon scented kind. shake it well and read the back for safety precautions. I am warning you to use care around animals and kids. That said : spray your part with a coat of the cleaner and then wait.... in 5 to 15 mins. the part will turn black , use some newspaper and wipe the black away , throw away the soaked paper carefully . Apply another coat of oven cleaner , wait, then wipe the black off. repeat untill the part no longer discolors black. usually 3 times a charm... but it is important that no black areas are left. 4 . Remove the top coat of masking after wiping the excess oven cleaner off and wash the areas with soap and water to remove any remaining ovencleaner . 5 . what you have left is a dull gray finish with no anodizing left, or fresh aluminum ready to be buffed with a spiral sewn wheel and tripoli. Then follow with a loose sewn wheel and white polishing compound. 6 . Use mothers polish or your favorite mag polish and a soft cloth then stand back and enjoy.... 7 . of course cast or scratched parts must still be sanded but Frames, swingarms ,rims, and engine covers are what this prossess is for..... :cool: Thanks and goodnite! |
Thanks for that YoungJester my swingarm looks like crap! I have tryed sanding the clear off my swingarm and i gave up. I will try your methed......
2 Attachment(s)
Originally Posted by super duper hawk
(Post 252933)
(Post 252933)
There is no "easy" way to do this guys. There is an "easier" and a couple "correct" ways to do it, but the theory behind making something shine is to get the surface like glass-as smooth as possible so it reflects light and doesn't send it in 90 different directions. No matter how you do it it's hard, dirty, and time consuming. I'd tell anyone to practice on a small part before you go trying to do your whole bike. That way you get a feel for how the process works. Once you do you can polish anything-aluminum, steel, plastic, even glass.
I'm a little ocd with detail stuff...so I don't mind sitting there for hours getting a part to shine. It's also addictive and soon you'll want to start polishing everything once you get good at it. But I don't think the process is for everyone as many folks would rather ride than clean and think any bike worth it's salt should have some dirt and grime on it. |
(Post 252950)
Good info youngjester.
Originally Posted by YOUNGJESTER
(Post 252931)
Will this method work on the lower section of the front forks. Mine look like crap.
If so, can I clean, polish and recoat with a protectorant of some kind? |
Originally Posted by YellowBird
(Post 252974)
If so, can I clean, polish and recoat with a protectorant of some kind? Also sometimes it's easier/safer/neater to brush on paint removers/easy off than spray it on. If it's a spray can spray it into a cap or small bowl first then use a brush. Always wear gloves and eye protection! |
(Post 252989)
They're painted aren't they? The easiest way would be to scuff them up and find a similar paint and clearcoat them. It depends on what kind of finish you want though. The term "polishing" is thrown around alot. Folks say they "polish" stuff with steel wool. It'll make something filthy shine more but to get something to shine like chrome you have to put in the work. Even after you strip off clearcoat/paint you still need to sand it smooth to do it properly. There really is no such thing as polishing without sanding. You can substitute some of the sanding with a wheel and different grits of an abrasive compound but the process is still the same.
HEY ALL.... THE METHOD I AM TELL YOU IS A PROVEN NO SAND METHOD , THE FRAME ON MY HAWK HAS NOT GOT THIS TREATMENT YET, I WILL DOCUMENT THE PROCEDURE WITH PICS TO SHOW HOW EASY, AGAIN I SAY EASY , THIS IS . JUST DON'T
SAND BEFORE YOU TRY IT , I SCREWED UP MY VFR FRAME A BIT BY SANDING IT, THEN I LEARNED THIS METHOD AND DID THE WHOLE BIKE WITHOUT TROUBLE, SO STAY TUNNED AND I WILL GET YOU GUYS SOME PICS, IF YOU LIKE SANDING AND DISMANTLING PARTS THEN GO AHEAD.. ITS YOUR TIME... |
YOU MUST STILL USED A BUFFER AND COMPOUND TO POLISH THE
ALUMINUM BUT THE SANDING IS DONE TO REMOVE THE ANODIZING THAT IS ON ALL MANUFACTURED PARTS , REMOVE PAINTED PARTS LIKE TANK AND FAIRING OF COURSE AND DO NOT USE ALUMINUM FOIL TO MASK WITH. EASY OFF REACTS WITH ALUMINUM ....! THATS THE POINT |
Didn't mean to offend you dude. There's always more than one way to do things. Your way sounds like an great way to remove clearcoat. But it doesn't offer much in the way of advice or technique on actual polishing. And it limits you to only the easy stuff that's already smooth. I can remove the clearcoat pretty quickly and at the same time be on my way to removing the machining marks and also any wear and tear scratches all with one grit of sandpaper with a small hand sander. And you HAVE to disassemble stuff if you want to get everywhere you can see and get professional results.
And as I already said you can substitute "sanding" with different wheels and grits of compound. Call it whatever you like it's still doing exactly the same thing and instead of having a black puddle from wetsanding you have a black cloud and black splatter in every direction from compound spitting off the wheel. Anyway I know how to polish and utilize both wetsanding and hand polishing, and also wheels and compounds. I'm not trying to bust your balls. Check out my old gsxr I built a few years back-you could shave it in. Post up some pics of your vfr I'd love to see it.
(Post 253054)
I couldn't hear over the shouting.
LOL I forgot about what caps means sorry, I am not offended.
I am just lazy with my keyboard. I love mines road. Any time you guy's want to meet up I am up for it. |
8541Hawk , Your Avatar is of a landmark across the bay from me,
any chance thats your place? |
Captainchaos I have seen your handywork and am humbled by the extent of your BLING wrench .
(Post 253091)
No Sand
(Post 253054)
ok I am off work and gonna start on my frame rails using my method, I almost wish someone would video the whole thing so that one would get the idea of time start to finish. Of course as Captainchaos has said the amount of "polish" is subject to ones level of mental disorder. I think my level is medium at least thats what my doc says, she's a Vetrinarian.
hey youngjester and 8541hawk am in the 707area we should get a ride 2gther whaen thw weather breaks
by the way thanks for the tip 'boutpolishing my hawk could use a buff
Hey all just posted the pics of the prosses I am sharing with you all.
not a single sheet of sandpaper was harmed from start to finish. the steps are cut down to half in this procedure because your not scratching a perfectly smooth part. Enjoy ...I am beat now... |
Originally Posted by Moehawk005
(Post 253124)
As for weather.... compared to most of the members we are doing good....lol |
Looks real nice Jester! +1 on masking everything off so carefully because when you use wheels the black splatter goes everywhere!
Seems to me everything you said in your origanal post was spot on. Kudos.
These are the kind of tips I look for on a forum. I'm all for doing things the easy way! Thanks!!
