Forum Feedback Post tips, comments, problems, requests pertaining to the Forums.
Need help with my forum account!
Old Apr 30, 2011 | 12:13 PM
AngryOlaf's Avatar
Somewhere in my account settings I switched it to a mobile or small screen view, and now the site is inaccessible from any computer when I am logged in!!!
For some reason the site is repeatedly redirecting to itself.
I can access it via iPhone using the new mobile theme, but nothing else.
Old Apr 30, 2011 | 07:52 PM
ninjagoalie's Avatar
I think...
Go to User CP,
then Edit Options (under the Settings & Options section) ,
then Miscellaneous Options (at the bottom) and
change the Forum Skin to default.
Old Apr 30, 2011 | 10:04 PM
AngryOlaf's Avatar
I know where the setting is but I can't get there. I am posting from my iPhone which is using a pared down mobile site with no control panel.
When I try to log in from ANY normal computer, the site breaks. Something in that simplified theme I applied is messed up and causes the site to endlessly redirect to itself.
Old Apr 30, 2011 | 10:41 PM
fred's Avatar
Mid-level Member
fred
ping Greg Nemish. he'll fix it for you.
Old May 1, 2011 | 12:48 AM
On the computer where you did that, go to settings and select "Remove all cached item's"... including cookies and whatever... That clears it... Greg can't fix it for you, since it's in the browser cache....
Old May 1, 2011 | 06:44 AM
AngryOlaf's Avatar
Hi Tweety,
It's not in the browser cache... It's in my account settings on the server. I've tried to log in from more than one computer and it breaks each time. Deleting cache and cookies only logs me out. Once I log in I am back in the redirect loop.
It is really the skin that is broken, but it renders my account unusable on any computer (aside from this phone which is on the mobile theme)
Old May 1, 2011 | 08:24 AM
Then on the phone, just scroll to the bottom, select "Normal Version" and you have access to all options... Then you can go to the options, and de-select the preference to have the mobile theme as your default...
The theme isn't broken, it's just not working on a non-mobile device, which it shouldn't really...
Old May 1, 2011 | 08:30 AM
AngryOlaf's Avatar
This phone is theonly way I have left to post and if I switch it to the full site I suspect the same issue will occur.
An endless series of redirects does mean the skin is broken. That shouldn't happen regardless of the browser/device.
Old May 1, 2011 | 08:46 AM
I can tell you from checking just now, that it won't break... But it's your choice... I managed the same a couple of days ago, when i selected the skin as default on my account...
The thing is, the skin is not broken... It's just not supposed to be used as a default theme... And the forum software have no way of handling that built in... The theme's creator explicitly warn you from selecting it as default on his webpage with information... I found that out as I researched this when i had problems...
So if you set it as default, the forum software screws up, since it get's the signal to default to a default theme since the computer can't view the mobile theme, and since the default is the mobile theme, the loop starts... Ie, don't set it too default, an all is fine... If you prefer to point fingers, point fingers at the software giys of the forum, not being able to separate mobile theme's from non-mobile...
Old May 1, 2011 | 09:50 AM
Angry-Olaf's Avatar
Angry-Olaf is on a distinguished road
Tweety - I am not trying to point fingers. I simply want to get my account working. (I will use this temp account in the meantime.)
I am also not crying out for help without thoroughly troubleshooting my issue first. I work in web design so it's not like I don't have a good grasp of how the site works or what is happening.
I did go ahead and try to get to the full version control panel from my iPhone and this failed as well. Even after clearing cache, cookies and history + restarting the phone... I am unable to get out of the mobile theme while logged in and cant access the settings in the control panel.
This really is something that can only be fixed by an admin or someone with direct access to the server database. Also - A theme that is this device-dependent and breaks the website for standard browsers should never have been installed, and really should be removed.
As an aside, I am beginning to suspect that there might be two mobile themes at work compounding my issue. The skin I selected from my iPad that started this whole fiasco being the older one, and the mobile theme that detects my iPhone and loads being a newer feature.
Old May 1, 2011 | 10:20 AM
AngryOlaf's Avatar
OK!
Found a way to fix it... had to type the exact URL from the control panel edit options page (from my new temp account) into my phone which was logged into my real account.
I do take back what I said about needing an admin, but this is still F'd up and should be fixed.
If anyone else runs into this problem in the future here is the URL to use from a mobile device to correct the setting (so you don't need to create a temp account to find it):
https://www.superhawkforum.com/forum...do=editoptions
FTL900
Dec 20, 2013 12:53 PM
collestat
Dec 26, 2012 11:23 AM
Peterbuilt
Dec 9, 2011 09:05 AM
newleader
Jun 18, 2010 09:07 AM
cagedruss
Jun 20, 2008 06:19 PM
