Share your mototcycling history
Just as the title says, lets share our motorcycling history as in what bikes you've owned, interesting stories, lessons learned. I'll start it off
My first ever "motorcycle" was a 2005 ADLY Jet 49cc 2 stroke scooter that was given to me for free, it didn't run, it had no headlight, or bodywork, it had 9k miles on it and had been sitting for over two years. Oh and it didn't have any keys. It belonged to the boyfriend of the daughter of a friend of my dads and he was tired of it sitting in his shed. He got the boyfriend to sign the title over but he had lost the keys. (Before you ask I checked the VIN on the scooter and the title and they did match)
I got it home and hotwired it and managed to get it running and broke the gas cap lock free so I could just turn it with a screwdriver. I rode it around the neighbor hood and was quite shocked that it actually got up to a gps verified 48-50mph. I then went on a shopping spree at places like Lowes and Harbor Freight and came back home with a 20w 12v halogen bulb which I stuck in a pill bottle and used for the low beam and one of the 55w fog lights out of the $15 set at Harbor Freight as a high which was bolted to the rear rack from the scooter which was bent and bolted to some brackets on the front. Now it had only one turn signal on the right rear and according to Florida statutes, if you have turn signals mounted they need to function but if no turn signals are present at all you can just use hand signals. So off came the signal. I got it registered and titled and for a total cost of $160 I was street legal. First day out on two wheels I have a lady pullout in front of me with less than half a car length while I'm going 45mph. I jam on the brakes and lock the front, let off the front as I swerve to the left, scooter starts falling down and I jam my left foot down at over 30mph and manage to keep it upright and make it to the red light ahead alive. (Remember this is my first day ever legally riding a two wheeled vehicle and to make matters worse I am (STUPIDLY) wearing sleeveless t-shirt, shorts and FLIP FLOPS!)
next to me at the light the lady pulls up next to me and I can't help my slef and angrily shout "You could of f***ing killed me!" to which she says as 4 kids are climbing around in the car unbuckled "Would you not curse in front of my kids." The light turns green and I take off, I see in the mirror she turns off and at that point I decide to make a u-turn and follow her. I see where she had pulled into a driveway and slow down to a couple mph so I can read and hopefully memorize her license plate number. She and I guess her husband or boyfriend starts yelling and I yell back "I got your plate number and will be reporting you!" I then start off again and go to make a u-turn down the street and angrily whack the throttle open while leaned over at 10mph in gravel and drop it. Picked it back up and headed home.
Lessons learned are...
- I assumed that since she looked at me she saw me, Assume you're invisible.
- Don't let your anger get to you.
- Beware of road conditions.
My second bike was a 1980 Honda CM400A Hondamatic that my father gave to me with a blown engine. He had bought it with 15k on it 3 years prior after 30k (45k now on the odometer) miles the cam chain guide came loose and wrapped itself around the crankshaft, luckily since it was the 2 speed hondamatic with a torque converter it didn't lock the rear wheel. He then asked me if I wanted to attempt swapping the engine and I proceeded to swap a 1981 hondamatic engine into it that was in a $100 parts bike he had bought prior. 10 hours later it was running on that engine which had 29k miles on it and had been sitting outside under a tarp for a decade. That lasted another 15k (60k now on the odometer) until metal shavings showed up in the oil. That's when he gave the bike to me and I bought a parts bike with a 400 5spd and a 450 6spd for $350 and swapped the 450 in and rode it for a few weeks before the started clutch disintegrated. I decided to buy a newer bike at this point because I could and because this was a 30 year old bike and even if I fixed the starter clutch there is the age of the bike to consider. (The started clutch is mounted directly on the end of the crankshaft so replacement required splitting the engine cases!)
My third bike was a 2006 Kawasaki KLR650 with a Stanley FatMax toolbox bolted to the rear rack. It had 31k miles on it when I bought it at the Barneys dealer in Brandon, FL for $2800 out the door. It had a slight weep from the water pump and thanks to the research I had done before hand I knew it was a seal or two and would be no more than $30 in parts to repair, I told the salesman about the leak and they threw in a $50 barneys gift card. The only other faults with the bike was the chuck missing out of the small firing the half the size of a fist, missing hand guards and one footpeg was missing a rubber cover. It was a fun bike but I managed to low-side it 3 times and in the process bent the subframe, and tweaked the frame. I ended up selling it for parts 8 months after I had bought it for $500. The rear master cylinder was held on with 20ft of twine, I regrettably beat the hell out of it being stupid but the reason I sold it wasn't just because of the damage but because I had just lost my aunt, mother and uncle to cancer within the first 6 months of 2012 and I realized I was getting too reckless on a bike and decided to sell it before I killed myself.
My third bike was that same 1980 Honda CM400. It was November 2012 I felt I could get back on a bike and be safe and since this Honda was still sitting in the garage I swapped the engine again and ... well ... long story short I didn't have the funds to fix it properly and was using what I would imaging being third world rigging and that only got me so far. When I had done my 4th engine swap (which only took 3 hours from rolling the bike into the work space to riding it out, compared to 10hours for the first time) in the thing I was on my final engine, one had seized it's self, one had a cam chain tensioner wrapped around the crank, another had a failing starter clutch and a rod knock.) This engine was starting to loose it's starter clutch and guzzled oil at a rate of 1 quart every 200 to 500 miles, the needles and everything it the carbs were severely worn and the intake boot were in such bad shape that nearly half oa tube of gasket sealant was used in them and then multiple bungee cords were used to hold the carbs against the cylinder head to minimize vacuum leaks. The front tire was starting to dry rot, the rear tile was balding, the chain was rusted, the rear sprocket was wobbly and at would only do 55mph and would slowly loose power the more you rode. ride for more than 10 miles and you'd have it pinned in 2nd gear doing 40 and struggling but I rode it like that for 2 months and ended up frying the CDI module and parked it.
My fourth bike is my 1998 Honda VTR1000 Superhawk with 46k miles on it.
I picked this up in mid January 2013 and the most interesting thing with it is that when I swapped the MCCT's in I didn't torque the mounting bolts properly or maybe it was because of the lack of loctite that the front mounting bolts backed out 2 days later and I bent the valves in the front cylinder head. What's ironic is that the sale of the 1980 Honda CM400 and all the parts for it is what's funding the repair of my VTR.
Here are some pictures...
Now lets hear from you.
Too much to write.... especially if I have to add all the bikes I ever rode, That would be 20 times the list I owned.
I'll just list the bikes I owned from the very first one
Piaggio 50cc
Vespa 150PX
Vespa 200PX
Suzuki GS 400
Suzuki GSX 750R
Cagiva 200 (Enduro 2 stroke street legal)
Suzuki DR 600
Yamaha XT600
Honda NX650
Suzuki RGV250
Honda Nighthawk 650
CBR600 F3
Honda XR650L (left to a friend in NY)
Honda Nighthawk 750
Honda XR650L
Suzuki DR350
Honda VTR1000F
Piaggio 50cc
Vespa 150PX
Vespa 200PX
Suzuki GS 400
Suzuki GSX 750R
Suzuki DR 600
Yamaha XT600
Honda NX650
Suzuki RGV250
Honda Nighthawk 650
CBR600 F3
Honda Nighthawk 750
Honda XR650L
Suzuki DR350
Honda VTR1000F
I had a Rupp mini bike with a 5hp lawnmower pull start engine. The block wore to where the crank vibrated. The con-rod snapped and judo-chopped the cam. A short block got it back on the road. The frame cracked at the steering head. The lawnmower shop welder didn't pull it back together enough before welding. Now I had a chopper. It had disc brakes but they never worked. I tried everything I could think of. I mostly drug my feet to stop. Right before I sold it I lubed the cables with WD-40. Suddenly awesome brakes.
I learned a lot but mostly that a manual is a very valuable tool.
I'll list the bikes I can remember,But I won't write an essay!1st gt 80,1981 mx 100 ,1982 xl 250,1978 yz 250,1973 bultaco 3somthing it never ran,1980 yz 125,1982 it 175'1979 CBX ,1981 cb 900f yosh'ed 1983 cb 1100f blue canadian model,never should have sold it,1988 Hurricane 1000,trx 250,Ex 500,Gs 500,RZ 350,1991 zx 7,yz 426 f,xr 650l,2008 ktm sdr(junk,sold) trx 500 rubicon ,cfr 450x, 1984 gs750 e super mod,and 1998 Firestorm.33years worth.Motorcycling really is a pastime!
Started with a Lambretta scooter at age 20, currently ride a Ducati Streetfighter and still going strong at age 70...bikes in between the scooter and the duc:
Honda CB350
Yamaha RT1
Yamaha DT 360
Honda CB550
Yamaha XS-1
Honda CB750
Kawasaki GPZ750
Honda CBR1000F
Honda VFR750
Honda VTR1000
Honda CB350
Yamaha RT1
Yamaha DT 360
Honda CB550
Yamaha XS-1
Honda CB750
Kawasaki GPZ750
Honda CBR1000F
Honda VFR750
Honda VTR1000
My dad had a Triumph 500 twin and a Velocette 500 after WWII. He sold the Velocette before I was conceived.
About fifteen years later, I returned from weekend away at a friend's cottage and discovered that my dad had bought a mid-60's Suzuki K11, the 80 cc. high pipe sports model. It was a complete surprise for me. My dad, who was frugal to a fault, just didn't do things like that.
He taught me to ride. Motorcycling was the only thing we could talk about for the next 10 years.
The Suzuki was followed by a Triumph Mountain Cub, a Bultaco Metralla, an H1B Kawasaki 500, a KT250 Kawasaki, an SR500E Yamaha, an NT650 Honda Hawk and, in 2002, a 2001 VTR1000F.
Ahhh let me reminisce, here's all the bikes I can remember:
1988 Honda Shadow 600
1998 Superhawk
Kinda fuzzy memories now. I can vaguely recall way back in 2009 taking what we called an "MSF" rider course. The sport has come so far since then!
lol you guys really know how to bring out the newb in me
1998 Superhawk
Ahh man ... ok heres what I remember
RM-125
KDX-175
RM-250
RM-500 (scary)
1980 Honda 400 Hawk
1984 XL-600
1983 Honda CB-1100F red (should of kept it)
1984 Honda 1000 Interceptor (Schleptor) with 4 into 1 Wolf pipe , loud !!
1983 Kawasaki GPZ-1100
1987 Suzuki GSXR-1100
1990 " GSXR-1100
1991 " GSXR-1100
1992 " GSXR-1100
current 1998 VTR & 2002 Yamaha R6 (trackbike)
RM-125
KDX-175
RM-250
RM-500 (scary)
1980 Honda 400 Hawk
1984 XL-600
1990 " GSXR-1100
1991 " GSXR-1100
1992 " GSXR-1100
'67 Hodaka Ace 90; '53 Triumph Thunderbird; '68 Honda CB 350; '68 Triumph Bonneville; '70 Honda CB450; '70 Triumph Tiger; '72 Cb500F; '66 Triumph Bonneville; '73+ BMW R75/5; '75 Honda 400F; '84 Honda 500 Interceptor; '99 Honda Superhawk
'85 Yamaha FJ600, '98 Suzuki Katana, '85 Honda XL600R, '00 Honda CBR929rr,
78 Honda CB750F, '03 Yamaha TW200, '98 VTR, another VTR
Still own T-dub, VTRs, and the CBR.
Ridden pretty much everything, anything I can get my hands on.
Geez you must be a geezer too, Had a Hodaka ACE 100 and a buddy had a Combat Wombat. Hell I haven't even heard the name Hodaka in 20 years.
Towards the discontent of my parents I purchased my first bike at age 18 a 1982 Yamaha XJ650 Maxim. I loved this bike and still do til this days as I refuse to sell it. Haven't hardly had to do anything to it besides replace the oem exhaust a it rusted through behind the baffle on the right side and fell of as I was racing down the interstate through St. Louis and I absolutely love the shaft drive. I now also own a 1998 VTR Firestorm I black. By far the fastest color...which I still owe you guys a pic of. And I must say the Vtr is the most fun bike I've ever ridden. As I just said it is a firestorm not a hawk although they are the same bike. I can't wait to bring it back to the good ole US. I must say I will miss the chance the military has given my to challenge the German twisties as I have eaten my chicken strips down to around a quarter inch. If anyone has imported a storm before I would love the advice on how to bust through all the red tape of bringing a bike back from Europe. I have been able to locate the EPA stamp on the pipes but not the one on the frame. Which leads me to believe that I will run into headaches. If Anyone could pm a pick of where the EPA emissions control label is affixed to the storm/hawk that would be great. Sorry of steering of topic. But this is a big deal so I don't have to sell my storm before I leave. Thanks
I think I'm up to 50+ bikes I've owned... just as many bicycles, too.
I pedaled coast to coast when I was 17, riding with local YMCA troop; just camped on people's front yards when available.
America was a different country back then.
I worked as a bicycle messenger in SEA and SF, received many "door prizes", totaled many bicycles but never broken a bone.
After working as a bicycle mechanic for a while, I moved onto dirt bikes; raced off-road, enduro, desert racing in CA.. and eventually got into street bikes for commuting and traveling. Rode across 49 states, including HI.. but never been in ND.
Current stable:
CBR1100XX
Superhawk
SV650S
Daily commuter Ninja 250
Kawasaki Sherpa 250
Kawasaki KLX300 dirt bike
Errand run Chinese 250 scooter
Current stable:
CBR1100XX
Superhawk
SV650S
Kawasaki Sherpa 250
Wow good topic
I first got the itch -when I would secretly tag along with older brothers to watch their friends ride Rupp mini bikes.
First riding was a friends mini bike probably @ 7. Then Honda Trails at camp about 12/13 yrs old.
Then due to being a broke assed white boy, didn't start riding to about 27.
Then
'82 BMW R65LS
'78 BMW R100RS
'88 BMW R100RT
Then my 1st new moto
2002 VTR1000f
I will ride as long as I'm able
ATGATT
I told U not to be stoopid u moron.
Then
'82 BMW R65LS
'78 BMW R100RS
'88 BMW R100RT
2002 VTR1000f
ATGATT
cushman mini bike
yamaha 250
ossa stiletto 250
1970 Triumph TR6-C Bought new, favorite bike!
1976 Kawasaki KZ750 (nearly killed me)
1971 BMW R75/5
1977 BMW R100RS tuned and cafinated
2002 VTR 1000F New favorite bike!
yamaha 250
ossa stiletto 250
1971 BMW R75/5
The first words I spoke were "Vroom Vroom" (are those even words?) As my father would pull into the driveway on his Shadow when I was a toddler. (AhhhHhhhh so cute ehh?)
My father purchased a 1980's Z50R when I was ~6 and I would zoom up and down a private road whenever my father could take me there.
Unfortunately: My mother did not want me on bikes so young and the Z50R was sold.
24 years later: I purchased a 1998 SH....
-Took my safety class, took the advanced safety class....
-Love working on mechanical things even if I don't know the proper verbiage for what parts I am working on or with......
Been a few months now, loving this beast and loving working and tinkering with it EVEN MORE!
In turn; instead of surprising the parents at first, I parked mine a mile away at a friends and walked to and fro before and after work. After asking why I was walking, and me not having an answer mom slicked the neighbor on me. Long story short motorcycle!
1994 Yamaha Seca 2 - Great beginner bike
1998 VTR slowly bringing her back to glory
First time I rode was at a Honda "Learn to Ride" program at the Houston Astrodome parking lot in 1971.
First bike was a Honda CL100. Followed by 40 years of riding Honda Elsinores, BSAs, Yamaha YZs, DTs and too many others to list.
Favorite bike was a 84 Honda Interceptor 1000. Was so much fun to ride.
Least favorite was a Yahaha DT250. Really didn't do ANYTHING well, but that is the nature with those old enduro bikes.
not sure if I can remember them all but i'll give it a shot
68 benelli 125
71 Honda sl350
72 Honda sl350
69 kawa 500 mach iii maybe a '70 cannot remember
71 Honda sl100
79 Suzuki pe250
85 Kawasaki kdx200
87 Honda cr250
91 Honda cr250
94 Kawasaki 250 4 wheeler
89 Honda nt650gt
02 Honda shadow sabre
01 Honda 919
06 Kawasaki kfx400 4 wheeler
04 996 super hawk
07 vfr800 anniv edition
10 crf250r
996, vfr & crf is what I have now
there may be another bike or two in there but i'm going back over 40 years, not sure if I got them all
68 benelli 125
71 Honda sl350
72 Honda sl350
71 Honda sl100
79 Suzuki pe250
85 Kawasaki kdx200
87 Honda cr250
91 Honda cr250
89 Honda nt650gt
01 Honda 919
04 996 super hawk
10 crf250r
Good topic.
My first ride was on a friend's stripped Honda 50.
My first bike was a Suzuki 185 Enduro I bought new for $700. I didn't care for offroad much, so I looked for a streetbike.
My second bike was a Suzuki GT380 two-stroke three cylinder. I replaced the 50lb stock exhaust with a trick 3 into 1 expansion chamber which made the bike lots more fun to ride.
My third bike was a KZ650 Kawasaki cafe racer with a 740cc kit in it and Z1 carbs. The bike was a wonderful beast with a great midrange pull and lovely pops through the Kerker 4 into 1 pipe on deceleration. Sadly, I slammed into the back of a car stopped at the top of a blind freeway entrance ramp. The irony is I was saving up for a second front disc brake kit at the time.
My fourth bike was a Yahama RD400 that I traded the Kawi wreck for. It was fun but I missed the 4-stroke sound and fury of the Kaw. The Yamaha was stolen twice and recovered once.
My last bike was a Kawasaki Ninja 600. Dead stock it was faster than the old 740 but the handling was rather twitchy and unpredictable. It lacked the charisma of my old 740 cafe bike.
Now I'm looking for a SuperHawk. I'm hoping it will have all the personality of my old 740 with even better handling.
This is current except for the five currently in my garage, and my sig.
OK, it's not totally complete. I forgot the Ninja 600, and I've had 2 GS-500 Suzukis, and I'm on my 4th Ninja/EX500.
74 Garelli 50cc basic moped
Honda Passport Super Cub 90cc thingie
82 Honda XL250
Old *** combat wombat (it was probably the coolest little bike I ever owned though)
74 Yamaha RD125b
80 something Honda CM250 Custom
82 Yamaha Seca 400 (one of my favorite bikes)
86 Kawasaki KX125 bored 1.0 over
80 something Yamaha DT50LC
80 something Yamaha XS750 (Seca style not cruiser)
80 something Yamaha XS1000 (Seca style not cruiser)
80 something Yamaha XS650
74 Yamaha RD350
75 Yamaha RD350 (both at the same time)
2000 Yamaha YZF600R
92 Yamaha FZR600
80 something Honda CB900
98 Honda VTR1000
And I know there were more in there somewhere that I don't remember
Ownership History:
1981 Honda ATC70 4 years old
1981 Honda ATC110 13 years old
1978 Honda XR75 13 years old (Uncle’s bike – Learned on it)
1985 Honda ATC200X 16 years old
1991 Suzuki Bandit 400 16 years old
1996 Kawasaki ZX-7R 18 years old
1999 Kawasaki ZX-9R 20 years old
1985 Honda ATC200X 21 years old
1982 Honda ATC185S 21 years old
2000 Yamaha R6 22 years old
2002 Suzuki SV650S 24 years old
2002 Yamaha YZ250F 24 years old
1978 Suzuki GS750 25 years old
1981 ATC185S 27 years old
1983 Suzuki ALT50 28 years old
2000 Aprillia RS50 28 years old
2002 Cannondale Moto 29 years old
2003 Cannondale Glamis 29 years old
2007 DRR DRX2 70 29 years old
2002 Cannondale E440 30 years old
2006 DRR 50 30 years old
2007 Honda CRF50 32 years old
1994 Honda CBR900RR 32 years old
1997 Kawasaki KDX220R 33 years old (Current Bike)
2001 Honda VTR1000 Superhawk 36 years old (Current Bike)
A few of these were my kid's bikes, I just listed everything that has been in my name (title-wise).
James
James
at a ripe age of 6
