Motus V4 Engine on Dyno
Old Jul 8, 2010 | 11:57 AM
Although the initial specs are not mind blowing, it could become a very cool platform to build off of.
http://www.youtube.com/motusmotorcyc.../0/2kooYoibfeA
Old Jul 8, 2010 | 12:06 PM
love that sound!!!!!
Old Jul 8, 2010 | 12:27 PM
alive226's Avatar
Great find.. Wow gotta love the way it sounds. Can't wait to see the bike run.
Old Jul 9, 2010 | 12:44 PM
LineArrayNut's Avatar
I could ride in
if it comes in less than 500 lbs wet i'll be surprised...
Old Jul 9, 2010 | 01:06 PM
well, considering the VTR weighs in at just under 480 lbs wet, a 1600 cc V4 with shaft-drive (and sport-touring equipment) can hardly be expected to weigh in only at 20 lbs more.....
Old Jul 9, 2010 | 01:45 PM
spladle160's Avatar
12 years later and more than 2x the price I would think they should easily be able to come in under 500lbs... if this wasn't their first bike. Nothing is perfect right out of the gate, it will take some tweaking but it should be a cool bike with tons of torque.
Old Jul 9, 2010 | 01:57 PM
look at the bikes it is meant to compete with, the Concours 14, the new VFR, the K1300GT, the FJR1300 none of them are anywhere near 500 lb wet (heck not sure if any of them are even under 500 lbs dry for that matter)...
Old Jul 9, 2010 | 04:35 PM
autoteach's Avatar
I know that reading is not our forte, but we can try. Go look on their site and you will see that they are hoping for a 500lb dry weight and that they are setting the bar at 140 hp, 120 lb-ft minimum output.
Old Jul 9, 2010 | 05:03 PM
And the rest of the proposed bike specs from their vague website ......
http://motusmotorcycles.com/mst-01.html
Chassis:
Chromoly tubular trellis spaceframe;
engine as stressed member
Front suspension:
43mm inverted telescopic forks, fully adjustable;
120mm travel
Rear suspension:
Twin spar chromoly swingarm;
fully adjustable pushrod monoshock with remote preload adjustment;
120mm travel
Brakes:
Dual 320mm floating discs;
dual 4-piston monoblock radial calipers;
single 2-piston rear caliper
Wheels:
17in x 3.5in front;
17in x 6in rear;
aluminum;
Michelin Road Pilot 2CT tires
Bodywork:
Composite
Dimensions:
Overall length 2130mm ( 84in)
Wheelbase 1473mm (58in)
Seat height 787mm (31in)
Rake 26º
Trail 108mm (4.25in)
Dry weight 227kg (500lbs) (est.)
Fuel capacity 22.7L (6gal)
Production date
2011
Old Jul 9, 2010 | 05:15 PM
autoteach's Avatar
they are telling quite a bit about something that isn't supposed to sell until next year (and it being the first year). I dont think they broke "cover" until May by what they showed for press releases.
Old Jul 9, 2010 | 08:26 PM
Red_Liner740's Avatar
umm pushrods? well guess we know this isnt going to be a screamer of an engine...
doesnt the V-Rod engine put out those sort of numbers?
Old Jul 9, 2010 | 09:02 PM
autoteach's Avatar
115-120 hp with 80 or so for tq. It won't be a screamer, but if you listen to the sound, and read what they have published thus far, they are aiming for a "american) sound. That being, a pushrod 350 sound. It does sound very much like an american v8, 90 degree v, the 75 degree crank, its all interesting.
st1300 - 112 hp stock, 120's easily with exhaust and k+n
http://www.cbxmanmotorcycles.com/CBX...ir-Filter.aspx
fjr1300- 140hp
bmw k1300gt- 160hp
http://www.cycleworld.com/article.as...article_id=920
concours 14- 150hp
vfr1200- 152hp
All in all, it will be competitive from the standpoint. If they made it similar in architecture to the small block chevy, than there are some possibilities.
similarities:
http://media.photobucket.com/image/c...9/heads014.jpg
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Attached Thumbnails Motus V4 Engine on Dyno-head.jpg   Motus V4 Engine on Dyno-chain.jpg   Motus V4 Engine on Dyno-crank.jpg
Old Jul 9, 2010 | 09:16 PM
autoteach's Avatar
Also, it appears to be open deck, which sucks, but it has a full girdled main (which you car guys understand). I am going to hang out on a limb and say that the crank is more substantial than most, and it beats a hardly hands down (shared journals, yes, but not homosexual rod-on-rod stuff)
http://www.indianpartseurope.com/xlrodkit.jpg
Old Jul 10, 2010 | 05:26 AM
My DT200 can probably beat a Hardley, hardly a measure of power there....
Old Jul 10, 2010 | 10:25 AM
What I don't get is why they both spin the engine the wrong way and use a chain drive.. that means they have to turn the power 90 degrees in the transmission to run the chain losing power and still have all the hassle of a chain.
If you are going to put the engine in sideways (such that the gyroscopic force it generates is a hindrance and not a benefit to riding) at least use a shaft drive.
As it is now they have all the disadvantages of all 3 issues. (longitudinal engine, power having to change directions like a shaft, and high maintenance of a chain)
It's stupid x 3
Old Jul 10, 2010 | 11:35 AM
drew_c14's Avatar
I think you all are missing the point of the bike. It's supposed to be different for the sake of being different. They wanted an AMERICAN pushrod V8 style engine that motor heads could identify with, and hopefully use that as a selling point. Also remember that it's a sport touring bike, not a crotch rocket, so the loss in power by using the push rods and the engine facing the wrong way don't really matter. Those features are exactly what make it appealing. I think it may do alright at first as a niche bike. In the end though it will go the way of the Buell unless they have figured out marketing and sales. No dealership is going to be in a hurry to put them next the easy to sell Japanese bikes.
Old Jul 10, 2010 | 02:32 PM
Fact is that there are definete advantages to go along with the disadvantages of that engine placement... So it's no more a compromise this way than the way the engine been placed on for instance the VFR...
Old Jul 11, 2010 | 02:13 PM
VFR spins the other way.. ST1300 is the same though.. In fact it just is a ST1300 in many ways..
Old Aug 11, 2011 | 10:19 AM
Erik S.'s Avatar
Is anyone out there following this. Motus has made a tour, including a stop at the GP race in California.
Engine numbers:
161 HP
122 lb/ft
Gasoline DIRECT INJECTION, first on a bike.
Dry weight is 530. Keep in mind it is a 100ci V-4 and has room for 6 gallons in the tank, plus the bags.
There is a "R" version which has Ohlins suspension and some other goodies.
A naked version has been made and there are videos of it on Youtube.
I've really been following them for about 1 month now.
Estimated price is around 20K. 500 initial build with plans for 1000/yr or more based on demand.
All American made. Pratt and Miller out of MI did the chassis and transmission. They have a background in American LeMans racing and NASCAR. Engine is by Katech, their background is much the same. Dual counter balancing shaft for the engine.
The transmission is a 6 speed, with a tall first, close ration 2, 3 and 4, with 5 and 6 being overdrives.
I want one.
Here are the links.
www.motusmotorcycles.com
https://www.facebook.com/#!/motusmotorcycles
2012 Motus MST-R | First Ride - Motorcyclist Magazine
Old Aug 11, 2011 | 10:40 AM
divingindaytona's Avatar
Remember stock is BAD!
Also this article
Motus: In Person « MotorcycleDaily.com – Motorcycle News, Editorials, Product Reviews and Bike Reviews
Old Aug 11, 2011 | 12:39 PM
dutchdude's Avatar
moto gp wannabe
dutchdude is on a distinguished road
I was reading about these in the mag a couple months back - that motor was basically a corvette motor cut in half and tweked to fit the bike. these guys are getting after it to be in production so soon. Wish them the best.
Now if Erik buell gets into production life would be sweet - american made sport bikes- F^&* Yeah
Old Aug 11, 2011 | 12:59 PM
vetlad1954's Avatar
vetlad1954 is on a distinguished road
Katech has been building Corvette C-5R and C-6R engines for a number of years. And can't help but notice similarities to Chevrolet V-8 engines.
Old Aug 13, 2011 | 11:52 AM
geekonamotorcycle's Avatar
Parent company Birmingham Motorcycle Company
Production 2012–
Engine 1,645 cc direct injection 2-valve longitudinal 90° pushrod V4
Bore / Stroke 86.5 × 70.0 mm (3.41 × 2.76 in)
Power 161 hp (120 kW) @ 7,800 rpm
Torque 165 N·m (122 lb·ft) @ 4,500 rpm
Transmission 6-speed, wet clutch, chain final drive
Frame type Steel trellis
Rake, Trail 26°, 108 mm
Wheelbase 58 inches (1,500 mm)
Weight 500 lb (230 kg) (dry)
550 lb (250 kg) (wet)
Fuel capacity 6 US gal (23 l; 5.0 imp gal)
Old Aug 13, 2011 | 12:07 PM
See if you can spot a certain yellow thing the test rider people are on
Motus Up Close - YouTube
If thats what they consider another great bike to ride then I have high hopes for this motus.
Old Aug 15, 2011 | 07:49 AM
Old Yeller's Avatar
That's cuz they wanted the fastest bike they could find to compare to!
It's way cool to see a new manufacturer putting a product out for the public just like Buell did. For my money though, I'd go with a VFR1200. Lots more technology and refinement, and with the extra cash, you can do lots to make it what you want.
Old Aug 15, 2011 | 02:01 PM
Erik S.'s Avatar
Old Yeller, I don't know about that. The VFR 1200 is only 1 year old, so refinement may not be applicable.
More technology, Pratt & Miller and Katech were involved, so there is plenty of technology there. Years of American LeMans racing, NASCAR and other racing series for both.
In the write ups and the videos, they left plenty of metal for the "consumer" to play with. A "bare" engine is how they described it.
Even with the extra cash, the VFR won't have the same type of power.
Just my opinion.
Old Aug 15, 2011 | 02:21 PM
Old Yeller's Avatar
yeah, I think it's a very cool bike, but at $20k, there aren't too many of us that will be able to afford to tinker. Plus I look at it as a sport-tour platform. I kind of compare it to the 1125R and CR that Buell put out before the demise. I got to ride one of those and it was da bomb! I gotta believe these bikes are just as appealing in their own way. but I also look at the VFR platform's refinement (in terms of Honda smoothness they are known for), and the tricks it brings to the table with the transmission. I'd personally go that direction if it was my money.
But I wouldn't mind swapping rides every once in a while with someone that went the Motis route.
Old Aug 15, 2011 | 03:38 PM
More technology, Pratt & Miller and Katech were involved, so there is plenty of technology there. Years of American LeMans racing, NASCAR and other racing series for both..
Yah I heard they were using some new tech called pushrods, gonna revolutionize the industry. 1 thing is for sure though. It will make very fast left turns no matter what.
Old Aug 16, 2011 | 07:46 PM
Erik S.'s Avatar
Wow, I see some sarcasm, and some ignorance.
New technology would be the Gasoline Direct Injection. First Motorcycle with it. Next sarcastic comment please.
As for the left turns, you obviously have not read anything about the companies. Since their primary interests are Corvette racing and American LeMans Racing Series. Right and left turns.
Not to mention, this sarcasm coming from the guy who has asked the most basic of questions.
Old Aug 16, 2011 | 07:49 PM
Hey Hey now. I was just kidding.
