pit bull non-spool adapters wanted
Old May 1, 2012 | 08:06 AM
chiknhauk's Avatar
chiknhauk is on a distinguished road
have rear pit bull stand w/spool only setup.need non spool adapters for stock hawk swingarm.thanks
Old May 1, 2012 | 03:17 PM
I am a PB reseller BTW. They have a combo spool/non-spool "top support" lift bracket set for $40, or just the "standard" top supports for $30, or U can buy the "standard plates" for $16 and weld them to the spool supports you have to result in their combo (see below links). Or U can by their spools and fasten them to the swing arm with riv-nuts; this mod has been extensively discussed (i.e., 6mm spool & drill out to .25" for ribbed steel riv-nuts available from Fastenal; be sure to counter bore spool backside for riv-nut relief and use SS SHCS.
Pit Bull Motorcycle Stands & Accessories: Supports (pair), SS Rear Stand
Pit Bull Motorcycle Stands & Accessories: Supports (pair), Standard Rear Stand
Pit Bull Motorcycle Stands & Accessories: Standard Plates, Forward Handle Rear
Pit Bull Motorcycle Stands & Accessories: Spool Kits
Old May 1, 2012 | 04:03 PM
chiknhauk's Avatar
thanks for the info n addresses.hoping maybe someone had an xtra set they don't need kinda cheap.not workn at this time,n gona use hawk as main ride to work.swapped motor(original had bad bearings),got to swap ft. rear tires,which i hav,find good used ft. sprocket n chain(hav rear).
maniac2313
Nov 13, 2010 10:40 PM
Rollin20z
Nov 22, 2009 02:12 PM
MUHerdFan
Apr 14, 2009 06:13 PM
skokievtr
Feb 20, 2008 08:29 PM
Opi
May 1, 2006 07:20 AM
