Engine parts for 2000 Super Hawk
Old Jan 11, 2007 | 08:54 AM
floridasroadkill's Avatar
floridasroadkill is on a distinguished road
Left over from a rebuild.
Engine died on oil starvation on main bearings.(wrong oilfilter)
Heads and the complette top end are great and don't show any signs of wear.
Also engine block, clutch, side cover,internal parts.
Old Jan 11, 2007 | 02:24 PM
kmm996's Avatar
kmm996
how much do you want for the side covers?
Old Jan 11, 2007 | 03:21 PM
meangreen79's Avatar
meangreen79 is on a distinguished road
Heads
How much for the heads.
Old Jan 11, 2007 | 03:52 PM
I would be interested in the jugs.
Old Jan 11, 2007 | 05:56 PM
JamieDaugherty's Avatar
Where are you located?
Old Jan 11, 2007 | 07:23 PM
Yeah, you're right and I hate to admit it but I thought it was two different (really three if you count both cylinders) pieces. After your polite PM I went to the microfiche and there it was. To further complicate matters, I already have one of those coming. When RCVTR was cleaning out his garage he had one in a box and I bought it. BTW When the engine loses oil pressure usually it's the cylinders and the valve train that suffer first & the most. The journals and main bearings are still splashing around in the stuff but the top runs dry immediately. You might want to measure some of the parts just to make sure they're good. Good Luck!
Old Jan 12, 2007 | 05:27 AM
How a engine works
Its very surprising how little people know about engines.
The crankshaft splashes in oil???
I don't think so.The mainbearings on the VTR(and so on many engines) are feed directly by the oilpump with high pressure oil.In some cases up to 60PSI.
And the designer do there best to keep the rotating crankshaft away from the oil. If the crank shaft is "splashing the oil" do to to high of a oil level,it wips it up to a foamy mush.And that means that the oilpump is pumping air ,and that means less oil and pressure for the main bearrings.
In this case it was a Yamaha oilfilter for a smaller engine that was unable to deliver the ammount of oil needed to keep the engine alive.
Why???
Maybe because the guy thought the crankshaft splashes some oil around and it will be fine.Piston and heads are in perfect shape,and are more in danger from overheating the engine do to coolant loss.
nfbzike
May 3, 2009 07:28 PM
J-Bird487
Sep 21, 2007 10:39 AM
YellowHawk2k1
Aug 10, 2007 11:34 PM
floridasroadkill
Apr 16, 2007 11:39 AM
floridasroadkill
Oct 14, 2006 04:52 PM
