parting out 1999 superhawk in Modesto , CA- corbin seat-ape cct-Wilbers shock
#64
#65
Eh, I can salvage my foot peg. As long as the actual bracket you have is straight I can work with it. Mines kind of bent in from landing on it so I can't mount stock exhaust any longer. That's the issue I'm having. I see from your original pictures you weren't using the mount either. As long as it's all okay I'll take the shifter and bracket.
#66
#67
Okay, I'll take them. Paypal?
How do the pegs attach anyway? Do you have any tips on changing this damn thing out? I never had to do it. I was just trying to install stock exhaust and it has gotten out of hand, so any tips are appreciated.
Thanks,
Kendrick
Thanks,
Kendrick
#68
The pegs are easy. You remove a circlip form the pin that holds the foot peg to the bracket; remove pin, foot peg and spring comes off. reassemble on the new bracket. Once you look at it you will understand. Just pay attention how the spring goes when you take it apart.
#70
#79
One oem radiator, wiring, swingarm, subframe, stator, flywheel, clutch, switches, airbox, carbs, rear cylinder head, valve covers, axles....
#83
#84
#85
Forks are for sale if I get $400. I got 929 triples and cbr1k forks for the cb-1. So the vtr set is up for grabs.
Parts in it:
FMGVS2040G.........RT COMPRESSION GOLD VALVE
FRGVSO2..............RT Rebound GOLD VALVE KT
FRSPS3534090.......RT FORK SPRINGS
Parts in it:
#87
Are the signals stock, are they still for sale can I see a pic? Email me at jonmueller1976@gmail.com
Rod knock in engine and cracked frame. So parting out the bike.
If you are looking for something that is not itemized and priced let me know.
Front end (forks with racetech .90 springs/ gold comp and rebound valves, triple tree, brake calipers, front wheel, rotors): $400
Bottom/chin fairing: $75 + shipping
Rear Brake pedal: $26 shipped
Shift lever assembly w/ bell crank and rod: $35 sold
Cylinder Head w/cams: $115 shipped-front cyl head sold. rear available
Piston and con rod set: $25 + shipping per side.
Clutch cover: $115 SOLD shipped. Water pump included, CPS not included
Wilbers rear shock( 200lb rider setup) : $450-Sold
Corbin seat: $200 + shipping
1 X Ape MCCT new in package: $40 shipped
blinkers: $15 each+ shipping. or $30 shipped for the pair-sold all.
Headlight: cheapest undamaged one on ebay is $215. that seems crazy: $115+ shipping.- sold
Subframe: $25+ shipping
Guage cluster (36000 miles): $100+ shipping- SOLD
Dr. Honda stacks: sold
Tail fairing: $135SOLD
Solo Seat cowl: $90-sold shipped
Passenger foot peg brackets: $50 shipped-SOLD
Ignition control Module: $50 shipped sold
ECU converter: $32 shipped sold
Left Rider rear set: $52 sold
Oil cooler: $10 -SOLD
Radiator, OEM , left side, undamaged: $50+ shipping
Radiator aftermarket, pair, undamaged, left side is unused: $70 sold
Clutch, complete with steels, fibers, inner hub, pressure plate, springs and bolts: $50 shipped.
^clutch with outer hub: $75
Sprocket cover: $20 shipped
Stator: $25 + shipping
Stator cover, clean: $65 Shipped- Will include a new oem gasket for extra $9-SOLD
Rear Wheel: $65 + shipping sold
Front fairing stay, air filter, handlebar switches and kick stand: SOLD
V & H pipes: Sold
pulse generator: sold
rear brake caliper: sold
Windshield: sold
Headers: sold
If you need something that is not listed, please ask.
If using paypal. Please cover the fees or send as gift. Thanks
V & H pipes: Sold
Windshield: sold
Headers: sold
#88
