joe6pack |
06-20-2010 06:22 AM |
Won't crank when hot
This would be the first problem I've had with my Superhawk. After about 40 miles of normal running on the Interstate yesterday I pulled off at a rest area and shut the bike down for about 5 minutes. When I tried to start it again all I got was a clicking sound, as if the battery was low or a connection was bad. I was able to bump start it by coasting down the exit ramp, turned around and rode it back home. When I shut it off at home it restarted normally and when I put the battery tender on it it came up to full charge in a couple of hours, indicating the battery was recieving juice from the alternator while running.
So WTF do you guys think it is??
