Will a RC51 alt cover.....
Will a RC51 alternator cover (left cover) fit on a superhawk?
Mine has a hole ground in it:headbang: Or, can the cover be heliarced? Or, does someone make a "strenghthend "one for track? ( I see ads for these in magazines, but they are all for, CBR's, R1's Gixxers, etc) Thanks |
Call a Honda dealer and check part numbers.
Heliarc? Dunno...isn't it magnesium? Can you weld mg? |
you can tig weld it........use the proper filler rod and make sure it is real clean by brushing it with a stainless steel brush before you weld it.
cloakerz, thanks, I will have to go to a welding shop and see how much that will cost. I used to use oxy/acetylene for minor welding/brazing when I was a auto mech in the 70's. I know very little about welding any other metals.
A new cover is $150. I dont know how much a used one would go for (if I can find one) redman, I asked one of the parts guys at a dealer, he said he "thought" a RC51 cover would work. so, I would need to be positive before I spent money on a part that might work. |
no rc cover will not fit.
welding will prob cost more than used off ebay. |
I asked a guy about welding (on another list, lives near me though), he said it would be expensive. I told him a new cover was $150 and that I hadnt found a aftermarket one. He said that he could get it done (and strengthen it) for less than a new one.( with the caveot that he needed to see it first and see how much damage it had)
