Will a R/R from an 04/05 R6 fits?
The question is simple.
Does anyone know if the R/R from an 04/05 R6 will fit right in my 07 VTR? Will it do a good job? |
If it's got a 5 pin connector it should work. If it's the 7 or 3 pin kind, no. If it's 5 pin you have to cut off the connector on your harness and either splice the Yamaha connector(not likely) or just crimp/solder 5 individual female lugs. I have one from a gixer and that's what I did. The Yamaha and Suzuki models are much better than the Honda since they have an aluminum enclosure with big cooling fins. So yes, it should do a good job.
Thanks.
But the question remains, will it do a good job? Has in, will it gets good charging numbers? The answer is probabily yes, but has anyone had it on his SH or VTR for more than one year with no ishues? |
