Go Back  SuperHawk Forum > 1997+ VTR1000F SuperHawk > Technical Discussion
Why do I need to service my brakes and Why don’t they work well after bleeding >
Old 04-22-2016, 12:10 PM
Why do I need to service my brakes every year or so?
And
Why do my brakes not work well after bleeding, they seem spongy but fluid is fresh?
Two common questions I get all the time.
Bike is a Bn125, fluid was recently “flushed” brakes remained all but unusable, spongy, no stopping power.. This issue is common to all bikes (and cars, trucks as well)
Pads showed uneven wear, side to side, normally caused on single sided piston calipers buy the caliper not moving freely on the slider pins (if you see that or front to back wear on a caliper with opposing pistons, you have one or more pistons not moving freely)
What I found in the caliper behind the pistons where they “should” have been only clean brake fluid is not atypical at all.
So if you have a squishy lever, bleeding has not resolved the issue, plan on servicing the brakes….Thats MC, the lines and the caliper.
MC piston set, caliper seals, new lines if your using rubber,
Some brake fluid, cleaner of your choice (the slider pin holes in the caliper may need to soak for a pit to dissolve old grease…or toss the disassembled caliper in your heated sonic tank…..LOL yes I cheat
And you're back in business .
E.Marquez is offline
Old 04-22-2016, 09:00 PM
Wow... Crazy
thedeatons is offline
Old 04-23-2016, 04:39 AM
Fastguy59's Avatar
Yes that stuff it a murky mess, put a magnet to it and you would be surprised! A nice fine slurry of fine metal particles mouisture, decomposing inner brake tube... yum. Change out your fluid even two years minimum, clean the clipper puck bellows gently, (I use a baby tooth brush and silicone) never seize the slides bits on the caliper and that junk is held at bay for along while. Nice work Eric!
Fastguy59 is offline
Randman
04-23-2016 04:47 AM
Circuit_Burner
10-14-2013 06:44 PM
j shizzy wizzy
06-21-2009 05:38 PM
Blurr
07-08-2006 01:55 AM
shayne
06-18-2006 03:45 AM
Quick Reply: Why do I need to service my brakes and Why don’t they work well after bleeding
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
