Wheel bearings went bad after 300 miles
I replaced the wheel bearings right when I bought the bike back in Feb of '07, the lasted over a year till about 3 weeks ago. I went in, had new ones put in, and now they are bad again.
What would cause bearings to fail in less than 4 weeks? I rode maybe 400 miles since they got installed.
any input?
And no, I havnt dropped the bike since I have owned it. But the guy before me dropped it but not bad.
any input?
Think it's an alignment problem. Bent axle, bent or damaged forks or maybe just one of them so they don't work together but flex in the bearing pockets.
It especially bothers me that the problem appears to be progressive ie you made it a year and then you made it 300 miles.
I would disassemble the front end down to the triples.
Check each fork leg for smooth and even operation.
Loosely reassemble everything. It should slide together like a fine shotgun or camera. While it's still loose shake it. This will help it self align. Then start tightening everything up to factory settings.
I've done this a couple times and I started at the axle-keepers and moved up the forks from there.
You might have also bent a wheel but this would show in braking - especially obvious shaking.
Good luck!
Good luck!
There are only two reasons that would cause a new wheel bearing to fail that quickly.
The bearing or bearings are not in straight. ( which should make axle installation difficult )
This happens when a bearing is driven in crooked and shaves aluminum off the bearing seat which ends up underneath the bearing, misaligning it.
This leads to side loads a radial ball bearing was never designed for.
Or:
The center spacer was left out, this will also cause a side load issue.
This should show itself when you tighten the axle nut and the wheel becomes hard to turn.
Look at Ref. # 6 in the attached illustration. That is the bearing spacer that keeps the inner race aligned with the outer race when the axle is torqued down.
Kai Ju
Or:
Kai Ju
I had a motorcycle shop install, im going back in tues to have them check it.
