what exactly does the converter unit do?
so im looking at running different coils on my vfr700, and i feel that i can nicely fit in some automotive coil over plug setups on this bike, but they are almost all under 1 ohm resistance.
my question is this. would i be able to use the converter unit with my stock ign module and run these low ohm coils? my stock coils are 3 ohms. |
Originally Posted by flyguyeddy
(Post 304363)
my question is this. would i be able to use the converter unit with my stock ign module and run these low ohm coils? my stock coils are 3 ohms. You're not going to run into any problems with the stock system so why swap out? |
