SuperHawk Forum
-   -   Whar size is the socket to remove clutch basket? (https://www.superhawkforum.com/forums/technical-discussion-28/whar-size-socket-remove-clutch-basket-29780/)
niteridder64 Feb 1, 2013 09:38 AM
I think it is about 30mm, thanks.
niteridder64 Feb 7, 2013 08:14 AM
Anybody know? Have parts in hand for the job except for the outer cover that says Honda on it if any one has one. Thanks
Wicky Feb 7, 2013 08:21 AM
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>CLUTCH
E.Marquez Feb 7, 2013 08:32 AM
30mm 12 point socket
captainchaos Feb 7, 2013 08:32 AM
Again be wary of the microfiche. It's been a few years but if I remember correctly the size on the microfiche was wrong.
captainchaos Feb 7, 2013 08:33 AM
There you go...and I think the fiche says 25 because I remember it being wrong
E.Marquez Feb 7, 2013 08:55 AM
The fiche is correct, but is referring to the thread size, ...not the OD or tool size needed.
niteridder64 Feb 7, 2013 10:38 AM
thanks guys
And thanks Captainchaos for the exhaust.
niteridder64 Feb 18, 2013 07:30 AM
Yes it is a 30 mm
had a hard time finding a 30mm 12 point but that is what it took. BTW you do not need a holding tool to torque the nut. Just put it in gear and slide a 2x2 piece of wood under the swing arm thru the wheel and under the swing arm on the other side. The bike is not going anywhere and you can make the 94 ft/lbs of torque.
sethnelsonnc Feb 18, 2013 09:42 AM
Most likely has reverse threads. Easiest was to do this job is with an impact.
7moore7 Feb 18, 2013 10:23 AM
+1, no impact needed if you don't have one.
