Water pump bearings
G'day.
We have had an Aussie member with an new VTR have a water pump bearing failure, and another member reporting an as yet undiagnosed noise in this area. Is the bearing suspect in the VTR? Is oil supply to this bearing a problem? (I cannot see a direct oil feed to it, it seems to be supplied by splash only). If this is a problem, would perhaps a sealed bearing be the answer? Any thoughts guys? Cheers, Shayne |
Re: Water pump bearings
No experiences guys?
I guess that means that there have been no problems then. |
