Turn signal switch delay?
So I've been noticing how my blinkers take a few seconds after I flip the switch to actually start blinking, and the right blinker doesn't seem to work at all if I push the switch too hard or not hard enough.
To me, this is a HUGE safety issue and is at the top of my "To-Do" list. Has anyone ever had this type of problem? My bike has just over 40,000 miles. Could this be some sort of short? I may just replace the entire switch unit if it's a cheap enough solution. In addition, I'm also installing a integrated tail light and new front LED blinkers. Should I do all this before I mess with the switch? I could shoot a video showing the type of delay I get with the blinkers, but I have no idea how I would get it on here. |
Disassemble and clean the switch... There is a gob of vaseline in there to keep moisture out, and after enough time and dust, that turns to a thick, sticky paste that isn't helping...
Also open up all the blinkers, and connectors and check for corrosion/resistance... That's also a possible delay... You shouldn't need to replace anything, just TLC... |
had the same problem and did the cleaning option. it didn't work for me. I ended up picking up a used one on ebay cheap and it was much better.
Mine does the same thing also. I know I need to take it apart and clean it just being lazy.
Its more noticable on cold morning rides |
Turn Signal Delay
My '99 does that and when I was checking it with the engine off the flasher relay would make several rapid clicks and then the blinkers will start working.
Could be low on blinker fluid as well. If you're low it'll take a few seconds to build enough pressure in the system to function properly. LOL
I think you may have the California turnsignals? These allow you to change lanes before making the other drive in the lane next to you aware of your intentions, so you can slide in to the 20ft gap that has just appeared in traffic. Once you you are safely in the adjacent lane your turnsignal will flash!
Also you can try headlight fluid if your local pepboys is out of blinker fluid! |
Mine does that for a week every spring after I get it back out. I just rock the thing back and forth for a while to clean it up, and once it gets warm it will work fine, and once it's above 50 the problem goes away. Yeah, just dirty. I don't know if OK is as bad as WI, but that's normal for me...
And yeah make sure the blinker fluid is topped off... |
I figured it was the blinker fluid because somehow all of mine were bone dry. I filled them all up with ID10T fluid and they stopped working for me all together. I drained the fluid replaced the bulbs and used a dryer fluid that has this weird stuff called A.I.R, I got it from the most unusual place. I then figured out It is a relay problem mine did the same thing and replaced the relay and works fine, Shitty design.
New to this forum, actually any forum but must say this has been a wealth of info already.
I picked up a very neglected, totally stock '98 in August with 8600 on the odo. ($1800) Some elbow grease, fresh fluids, and new rubber perked her right up and she has been a great partner in crime for 3k miles. The only issues I have had were the charging (or lack thereof) and now the turn signals. Solved the charging issue with the help of the info on here and Electrosports excellent troubleshooting schematic. The only thing that would have made it a shorter process is knowing that there really is not + charge until approximately 3500rpm. Had I known this and tested there or above with new R/R installed it would have saved some time not having to complete the flow chart. The blinker gremlin sounds similar to what others here are dealing with. It seems intermittent but mostly when cold and have noticed it more with the change in weather. Warm it can work normally but cold it can be up to 5 second delay on left and even 10 on right. I have been through the switch and all connections and nothing obvious, all clean and solid connections. It makes me assume (yikes) it is the relay per 3amta3. Any ideas, refutes or confirmations would be greatly appreciated. Also any info on sourcing a new (preferably) one at non-Honda prices would be very welcome. |
I pulled my blinker assembly apart, cleaned each part, and regreased the entire assembly. It's not perfect, and there is still a 11 or 2 sec delay, but it's consistent and much quicker than before.
the relay is not real expensive. go to hondapartsline.com cheap OEM parts. you could even use a standard turn signal relay from the advance auto just hook the wires up right and will work like a champ for about half the price.
yeah, I agree. I'm still experiencing it, and I believe it has to do with the relay switch and/or the bulb not pulling enough energy to get the blinking started quickly.
Worst case we've all got arms for Hand signals eh?
Originally Posted by mertechperformance
(Post 317663)
Originally Posted by bbad667
(Post 317649)
I picked up a very neglected, totally stock '98 in August with 8600 on the odo. i was lucky too, only paid a little more than you for a 99 with <10000 miles last year. im already up over 20000 and another 2g in OEM + custom retrofits love the volume of wealth that is contained in this forum :congrats::wootwoot: ive had stupid ideas many times.. and also followed many great steps to be creative and make others ideas better. also people here are always selling parts that you might need. look in the classifieds im using spare parts currently to still ride with intentions to upgrade their stock parts for however long it takes me... when im done i embark into my next project and you will see my stock parts up for sale. -b |
Thank you for the responses. I feel a little better in my own skin with operating turn signals and still tend to use both bike and hand signals. For just shy of $50 on bikebandit (couldn't find on hondapartsline) I believe a new oem relay is cheap "assurance" and most likely the culprit.
Who does only ride one of these amazing bikes 8600 miles in 13 years??? Nobody I want to meet unless they are signing over the title for $1800. |
(Post 317679)
Just to revive an old thread... My left blinker flashes flashes normally and my right flashes only when ut wants too and the turn is usually completed by the time it flashes.
Are these earthed independently? Where can I find the relay? Is anything going to spring out if I dismantle the switch block? Sorry for the questions. New owner and slightly frustrated at Honda "reliability". |
Originally Posted by 2wheelsagain
(Post 366424)
Are these earthed independently? Where can I find the relay? Is anything going to spring out if I dismantle the switch block? Sorry for the questions. New owner and slightly frustrated at Honda "reliability". Also check each light connectors and bulb sockets for corrosion. The turn signal relay is under the rear cowl, right hand side just behind the regulator / rectifier. Disconnect the relay connector Short the white/green and gray wire terminals of relay connector with a with a jumper wire . Check the turn signal light now with the ignition switch on.. If the lights come on , check for continuity between the green wire terminal and body ground. If you have continuity, the terminals connectors are tight, clean.. replace the relay |
(Post 366426)
Likely it is old, cruddy lube in the turn signal switch causing the issue.. remove the left side switch assembly, disassemble switch, clean pasty crap out, use a dab of fresh dielectric silicone to block moisture and lube.. check signal functions.
Also check each light connectors and bulb sockets for corrosion. The turn signal relay is under the rear cowl, right hand side just behind the regulator / rectifier. Disconnect the relay connector Short the white/green and gray wire terminals of relay connector with a with a jumper wire . Check the turn signal light now with the ignition switch on.. If the lights come on , check for continuity between the green wire terminal and body ground. If you have continuity, the terminals connectors are tight, clean.. replace the relay I picked up some "electrical quality silicone lube" today. Would that do the trick or does it need to be a grease/paste type blocker? I have a multi meter so I can handle the relay. Thanks for the info :) |
(Post 366451)
That sounds like I job I can handle over Christmas while its too hot to ride here :)
Anyone ever had the running lights work, but the turns won't? I have LEDs rear, an integrated taillight, and a new relay inline. Everything worked OK, until I tried to replace the front signals last week to LED bulbs...now they don't want to blink when the switch is activated. I've cleaned the switch & housing, but no luck. Ideas?
LED Specific Relay LF1-S-FLAT Universal Motorcycle Electronic Flasher | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
I have LED's all around, works great. |
I also have part time blinkers but.....
What I have found is the relay seems to need to be energised. That is once the blinkers are used a few times on both sides mine come on instantly. Its fine if its used all day or every day but leave the bike for a couple of days and we're back to part time. So I'm thinking there is a capacitor in the relay that is losing charge. All I do is have the blinkers flashing while I suite up and all is well for the rest of the trip/day. |
Ahh no. Its just a coil and a set of contacts I'm afraid. Have you tried all the good suggestions mentioned in this thread that would lead you to believe it is not just a marginal connection somewhere?
(Post 317663)
Originally Posted by Upland111
(Post 371040)
Yep I've cleaned and re-siliconed every join and contact. The only way my blinkers work reliably is to use them everyday. :o |
Have you completely disassembled the turn signal switch, cleaned out the old sticky lube around the moving parts in there and re-lubed and re-assembled?
(Post 317649)
New to this forum.... The only thing that would have made it a shorter process is knowing that there really is not + charge until approximately 3500rpm.
On the blinkers, I've had the same delay and spent a while checking everything on my last VTR.. I had a few spare relays and some worked better than others...I'm had similar experience with 2wheelsagain, where once you get the blinks to work on both sides, then they work quicker...It's just the initial few times that are MORE delayed. |
