SuperHawk Forum
-   -   Track Bike cooling (https://www.superhawkforum.com/forums/technical-discussion-28/track-bike-cooling-18452/)
budman Apr 26, 2009 08:46 AM
Track Bike cooling
My SH is a track bike and will never see the street again. I want to remove the left radiator and just run the right with the fan. I would probably put a switch on the fan for waiting on pit lane. Any thoughts.......
hawxter996 Apr 26, 2009 08:50 AM
two words ,over and heat.
not a good mod for the track.
you want more cooling not less.
mikstr Apr 26, 2009 09:08 AM
if track days are the sole use for the bike, ditch the fan, it will help improve airflow through the right rad, and hence improve the cooling. You may also want to look at the possibility of putting on a larger oil cooler to help further.
JamieDaugherty Apr 26, 2009 09:18 AM
+1
Hotbrakes Apr 26, 2009 04:52 PM
Yeah, mine always runs hotter on the track. Heat robs power. Are you trying to save weight or something? Another oil cooler would be nice. I agree with removing the fan too to improve airflow, but watch that guage, especially if you are running straight water.
RymerC Apr 26, 2009 04:56 PM
Are you guys overheating? Even after 30 min sessions I don't get close to halfway. I don't know what that translates to in F degrees though. Maybe I need an oil temp gauge.
JamieDaugherty Apr 26, 2009 05:02 PM
I don't even get that hot. Even around Mid-Ohio in August! In fact, my bike runs at the first line just like it does on the street - no different. When you come off the track if you sit on hot pit lane with it running too long the fan will come on, but that's no big deal. While I'm moving everything is a-ok.
gboezio Apr 26, 2009 07:29 PM
On the track, I'm at 98°C all session long and I have two rads.
dshakes Apr 26, 2009 08:10 PM
mine gets hot if i sit in slow moving trafficor if i ride hard. Hovers just low enough to keep the fan off. does kick on time to time though. bafflectomy make it run warmer?
Red_Liner740 Apr 27, 2009 06:56 AM
aftermarket pipes or bafflectomy makes the bike run leaner = hotter temperatures...
dshakes Apr 28, 2009 10:04 AM
Any suggestions to run a little cooler? It was 85 yesterday and in traffic it runs warm-fan on here and there-even cruising at 35 or so it runs warm. Hate to see when its 95!
JamieDaugherty Apr 28, 2009 10:07 AM
That doesn't sound right. At any moving speed your fans should not be running. My bike doesn't change at all, even at 100 degree temps. It sounds like your thermostat isn't working right.
budman Apr 28, 2009 01:33 PM
I ran my hawk on the street for 3 years befor track duty only and I dont ever remember the fan comming on. I remember testing it several times just to make sure it worked. BTW bigger oil cooler shoud be here by fri
dshakes Apr 29, 2009 01:18 PM
Suggestions on testing the problem and a solution? Still a novice in the tech department. How hard of a swap would that be?
