top yoke nut removal
Ok now this is probably a noob question but dont laugh at me
Ive never removed yokes from a bike before or had the necessity to ever undo a top yoke nut so can i take my top yoke nut off and replace it easily as it looks like crap and i want an anodised one or if i undo it will my forks fall out or something lol thanks lads :confused: |
yes you can remove it. there is a nut and retaining washer under it that sets the torque on the head bearings.
tim btw: if you go anodized get some plumbing teflon tape and wrap it around the new nut to prevent scratching it up as you tighten it. |
good call on the tape!
so i can just remove it and screw the new one on but ill need to make sure its at the right torque when i put it back on? what torque setting should it be at? |
Originally Posted by Forde
(Post 231624)
so i can just remove it and screw the new one on but ill need to make sure its at the right torque when i put it back on? what torque setting should it be at? tim |
| All times are GMT -7. The time now is 07:27 AM. |
