telltail hole
My telltale hole is seeping,should i be worried? What do i have to fix.
Penicillin
(Post 64297)
Penicillin
Smart asses.:crackup: :rolleyes: :boink: :rotf:
Isn't that the water pump? |
(Post 64297)
Penicillin
seriously, wtf are you taliking about? |
Does it itch?
That sounds like the water pump seal/bearing is starting to go... You should probably think about having it replaced by the dealership or get the parts and do it yourself - I seem to recall you will need access to a press to get it removed and the new one pressed in though.
some of you guys are to funny.
its the water pump seal thats leaking. you can use a large C lamp to press the impeller in and out of the case if you don't have access to a press. good luck |
Does "it" burn we you take a leak................
How bad is it seeping. This is a noted characteristic for the VTR1000. If it is a little snail trail every once in a blue moon, dont worry about it. If the leak becomes more prominant, then look into replacing the waterpump seal. My 98 has over 30000 miles on it, and I never had more than a couple of dribbles here and there.
thanks guy's, my bike has 55000 mi on it but it is just a small weep, just noticed it a few days ago and wiped it clean, hasn't come back yet. But what if it does hurt when i pee?
Doxycyclin will clear that right up, no problem. 200mg day one, 100 per day for the next 10. You have to eat with it though or it will make you wicked sick.
So while i was out riding todayi noticed that my fan was not kicking on, probally why my bike was hot, probally why it leaked. Tested everything accoring to the book and came to the conclusion that my fan is junk. Ahh poo.
not to sound like too much of a noob, but I just got my 98 vtr a week ago, where is this telltail hole (on the bike)
nevermind, I didn't scroll to the bottom of the page and there's a thread which has the answer. sorry
