Tappet adjuster size
So I plan to buy this tool to ease my valve adjustment but what size should I get?
Motion Pro - 08-0582 - 3mm Sq. Tappet Adjuster Tool with 8mm Socket Wrench | eBay |
What vehicle will you use it for?
(Post 402443)
Motion Pro - 08-0582 - 3mm Sq. Tappet Adjuster Tool with 8mm Socket Wrench | eBay if you know that and your asking for use on some other bike, then yes, the Motion Pro tappet adjuster works well, I have several in different sizes. |
Revised question, best place for shim kits? Or do I buy a bunch individually?
Smokin,
I just went through a valve adjustment. Bought a hot cams kit. Good luck. |
Originally Posted by kenmoore
(Post 402454)
Smokin,
I just went through a valve adjustment. Bought a hot cams kit. Good luck. Not the same kit. It was a Wiseco. Same deal though. |
(Post 402453)
If buying new, order a Hot Cams 9.48 mm shim kit from Amazon and be done with it. |
Originally Posted by xeris
(Post 402458)
Same kit I bought. Still had to order individual shims because the kit is not graduated in small enough increments. Other than that it worked great.
But I have never NEEDED an OEM 1/2 size shim to get valves into spec.. Wanted yes....needed no. |
So Erik where am I getting the used kits? Post a link if you can.
So I found the hot cams kit then the hot cams refill kit on ebay. Whats the diff? |
The Hot Cams kit has the full range of sizes, and (IIRC) 5 of each. The refill kits just come with a single specific size so you can "refill" the kit.
(Post 402464)
So I found the hot cams kit then the hot cams refill kit on ebay. Whats the diff? Little different for me as I don't have a bike waiting on them so I just search once a week or so and if one pops up I buy it. Folks buy the kits, use one once, sell the bike and then later find the kit in the garage and sell it. Hot cams refill kit is a 5pk of one shim size to "refill" main kit when you use up a single size. The full kit comes with 3 of each size which works out 99% of the time..but occasionally, you will need 4 same size shims I think I can remember that happen only once in the last 20 years or so. Another option is to see of a local shop or dealer will "swap" shims with you.. You bring in a 2.05 and they swap you a 2.00 or something. That is a hit or miss deal...... I might do it, if it did not zero balance me on the size you needed, but Im not going to give up my last 2 size XX. I have also swapped at a small price...like the refill price.... per shim. So you need a 1.89, 2.00, 2.10 2.05 shims...and am down to 1 of each... Id give them to you but ask for $22, the cost of ordering a refill package of each of those shim sizes. |
(Post 402462)
None of the after market kits come in "Half sizes" only OEM shims come that way
