Super Sprox Counter Shaft Question
Just ran into this issue. Old sprocket (OEM) is measured at 16.89 mm and the new one measures at 16.77 mm in thickness. my issue is that there is a bit of side to side play with the new sprocket installed. I am not sure if I I have the wrong sprocket OR if I could use a washer on the back side of sprocket to push it out just a bit more. Thanks.
Me thinks it's a variance between manufacturers, not really anything to worry about. The chain doesn't try to move sideways, just front to back :)
James |
Non issue. Mount it up and go. ;)
Thanks guys! I think I should be riding tomorrow!
a little bit of side to side play is necessary on the CS sprocket.
| All times are GMT -7. The time now is 08:24 AM. |
