strange groove running down the middle of the tire?
a sign it's toast ;)
Originally Posted by slo1
(Post 363686)
Hard to tell from that pic. The tire has wear bars to show you when its done. Take some pics of the treads.
I've seen a tire with two different tire compounds have a line kind of similar to that when the tire wears down.
I don't know...now that I look at it, that line looks like you did a burn out (or just spun the tire a little) a while back and got a deep groove in the tire from it, then the tire wore down to the point you see it now. |
(Post 363690)
[QUOTE=CruxGNZ;363691]I've seen a tire with two different tire compounds have a line kind of similar to that when the tire wears down.
I don't do burnouts with touring bikes I don't know...now that I look at it, that line looks like you did a burn out (or just spun the tire a little) a while back and got a deep groove in the tire from it, then the tire wore down to the point you see it now.[/QUOTe I don't do burnouts with touring bikes. |
Will I see cords?
Dude, spring for a new tire. Your life is worth it. Not to mention how horrible the hawk handles with even light wear.
(Post 363699)
Originally Posted by jerryh
(Post 363703)
Rear sure locks easy slowing straight, the edges are still good though.
Ill look for cords then stick a tube in it for safetys sake. Did dragon and cherahola yesterday and cherahola twice today. Edges are getting some use. Good thing I have a 190 on standby I bought for $40.
(Post 363706)
Sweet roads, now do them again with "vigor" and get to the wear bars on the sides. Or I can sell you some "pre scrubbed" track take offs ;) |
(Post 363707)
You at least get your moneys worth ;) be sure to use the "radial" tube.....
slo1* followed quickly by a really loose feeling in the rear......
Hahaha lmao loose in the rear Its a maypop may pop may not |
That's pretty normal, actually. It is where the rubber nitted together in the molding process. Don't stress over it - all is goood.
(Post 363715)
:iagree: |
Thanks guys!
http://i1301.photobucket.com/albums/...ps59e7f838.jpg
Bought this off ebay. Interesting what you find when peel off the sellers label. I tried patching then pluging. Still would not hold air. Purchased from Elys out of FLA I'll be giving them a shout next week. |
In my vast ebay dealings, no one pays attention til you open a case. Say it wasnt as described and unsafe. Thats when you get a response. Or you can get an innertube.
If you need bargain rubber I have a tire that will still pass inspection. But like I said, a dunlop roadsmart is $100 to your door (shipping incld) from the superstore. |
Thanks Joe. You did the tube thing not too long ago. How'd you deal with the valve stem and rim? Roadsmart...I'm looking for something I can get 10k or so out of.
10k and you bought a hacked take off? Methinks there is something amiss.
The roadsmart is a lot of mile for the monet as its dual compound. You may or maynot beat it with a touring tire but you'd loose a bunch of grip. You should have no prob fixing that tire with a mushroom patch from the inside. Just use brake cleaner to prep the area and a bunch of rubber cement. Tube has been a Godsend, you just cut out the old valve stem. Simple |
(Post 363877)
1 Attachment(s)
Dude, you have like an 1/8" chicken strip left....pffft...wuss
Originally Posted by CruxGNZ
(Post 363906)
http://i1301.photobucket.com/albums/...psb7e74fbe.jpg Fronts are even fatter :) |
Hey guys the 190 road2 I bought off elys auto off of ebay update. Spoke with them this morning and they said they would refund my card in full by tomorrow and I get to keep the tire. Pretty cool
(Post 363906)
:) What'd ya expect man?! Its Florida! Aint no curves in FL! :p An I agree with smokinjoe, a mushroom patch thing from the inside-out will fix her up good...worked on mine for a couple thousand miles...would loose air over time, but just check before you ride. Should be doin that anyway, right ;) |
Originally Posted by Bandit400man
(Post 363929)
Went to pep boys trying tob track downa mushroom. Will try firestone next
