Sticky Speedo
Hey Guys, quick question.
When I accelerate through the full sweep my needle sticks at about 160, the jumps when i hit about 180-190km/h. Sometimes it will stick past 190, then jump to 230km/h, which is no good, i like to know when i am going past the "Ludicrus Speed" marker. Is there anything i should lube? I think the speedo works with a pulse generator or something, so it's probably in the clock internals, but i don't want to start pulling that all apart. I might break some tamper seal or something. Anybody else ever have this problem? |
the speedo is electronic driven, you may be able to find a local speedometer shop that can repair it.
Originally Posted by Arctic Fire
(Post 37023)
Is there anything i should lube? |
