Sticky... brakes
Ok the best way I can describe this problem is that my front brake is...well sticky or jumpy... not smooth. I think the problem is somewhere in the brake lever, and I see the boot that the lever depresses on to apply pressure to the brake lines. So did anyone else have this problem, and can is there a way to lube inside that boot to allow the brakes to be applied more smoothly?
Not really a superhawk specific question I konw but this was really pissing me off today and a search of the forum did not turn up any results for me. -Justin |
You're talking about a sticky lever, right? Not sticky brakes? If so, use white lithium grease. Apply liberally to the part of the brake lever that depresses into the master cylinder. That should help.
thanks
allright thanks, I put some wd-40 on it now its good. Peace.
Justin |
