Steering stem torque with aftermarket bearings?
Yes but.....
The bearing install instructions state
But I think that is more for liability reasons then anything.
End of the day you want just enough preload to remove all clearance... There is no need for clearances on a bearing of this type and application (vs a wheel bearing say)
Too much preload and you have binding.
The nut on top of the triple clamp is tq'ed to OEM spec
"b) Place the upper bearing and seal onto the stem. Thread the spanner nut back onto the stem. Torque spanner nut to factory recommended levels. c) Place the top triple clamp and washer back into place thread the top nut back on and torque to factory recommended levels."
What I've always done is this:
1-barely finger tight, move left to right to get a feel for how it is with no torque on the bearings
2-gradually tighten until just a bit of binding is felt when moving left to right
3-back up just the tiniest amount
And if in doubt just repeat steps 2 and 3
Location: South of Live Free or Die & North of Family Guy
My way (though maybe old fashion) I trust the most, front in the air just a bit, while the bike on the side stand, using just gravity, if the the forks fall from right to left quickly, it's too loose! If the forks don't move by gravity, it's too tight.
The forks needs to travel slower then falling, but smoothly from side to side, that's how you know the bearing actually rolling correctly.
Again, it's a crude and simple method, but works perfect for almost any bike.
Once you ride with the new bearing for few hundred miles, I would check them again, as they may have been settled a bit and got looser.
I went through the same line of questioning last month, the answer lies in the manual and it requires a fishing scale. Use the pull test on each bar to achieve the proper drag. Go slightly heavy as the bearing will seat in after a while. Much less torque is required for the tapered rollers without a doubt.
AV
AV
theconundrum
01-22-2015 08:47 PM
Wolverine
07-13-2007 10:28 PM
