steering stem size
I'm looking for the sizes of the OEM steering stem for the SH. Specifically, the diameter of the shaft at the bearing points (upper and lower), the diameter of the portion of the stem that gets press fit into the lower triple, and the length stem between the bearings.
Looked online and haven't run across actual measurements. Hoping someone has one oute of a bike they can measure/verify. Thanks for the help. |
Cant help much but I have a set of new bearings right next to me and the verniers say the ID of the bottom bearing is exactly 30.00mm and the top bearing is exactly 26.00mm
Thanks.
