Steering damper mounting question
Hello everyone! Yesterday scored a great deal on a old but barely used Hyperpro csc steering damper with mounting hardware for the superhawk. After bringing it home, the tank mount (two tank bolts) align perfectly; however the top triple mount ring is of much larger diameter than the top nut. I assume I’m missing a washer or ring of some sort - was wondering if anyone that possibly has the same damper could guide me on the part/installation I’m missing. Photo attached - shows mount and the ring diameter which the top nut clears with a good amount of space. https://cimg0.ibsrv.net/gimg/www.sup...4f6be5f6e.jpeg |
https://cimg2.ibsrv.net/gimg/www.sup...e0199d2edd.jpg
Looks like you do not have the correct mount..or it has changed significantly from what you have to current issue https://www.hyperonline.nl/contents/...uurdemper.html https://www.hyperonline.nl/contents/nl/MK-HO10-T005.pdf |
Or the mount hardware isn't for a SuperHawk, but for a different model.
Looks like I’m machining a new mount haha. It’s one of the original units made (before they went to the aluminium one shown in the PDF). Tank mount bolts up perfectly - I either got the wrong top-clamp part from p/o, or I’m missing a part. Will also try contacting hyperpro for mount upgrade to get an idea of cost.
Originally Posted by 2.5i
(Post 407219)
Or machine an aluminum mount.... But id be cautious on that as without non destructive computer aided analysis Id way overbuild it, and they its going to be obnoxiously large. Think Id make an adapter from some 4130 steel or buy a new factory mount. |
Drew up a quick sketch to have this turned. Will update with a photo when it’s done! :) |
(Post 407227)
Drew up a quick sketch to have this turned. Will update with a photo when it’s done! :) or did you mean an adapter ring? |
It’s a 9 axis mill! Haha not having the entire mount done - just a stepped ring :) countersunk nut and clearance for 30mm socket made it more complicated, but should work nicely.
(Post 407235)
It’s a 9 axis mill! .
