SuperHawk Forum
-   -   Speedometer not working, then working again (https://www.superhawkforum.com/forums/technical-discussion-28/speedometer-not-working-then-working-again-19307/)
superman_006 Jun 26, 2009 05:29 PM
Well just as it says, I took my 98 superhawk out today, I washed it and I didnt notice if it was working at first, then I was crusing and noticed it was sitting the peg (0) and the milage wasnt working. I stopped and ate somewhere and when I got on it again it was working fine?
I did the search thing and it sounds like the speed sensor is pretty reliable. Is there anywhere I should check for corrotion?
Little_Horse Jun 26, 2009 08:48 PM
it may be your regulator rectifier, they do that when they start to go out, its no longer letting enough voltage get through to run the gauges and after you park it the r/r cools then works again for a little while
Circuit_Burner Jun 26, 2009 09:09 PM
Yea if your battery or voltage levels do anything strange soon, you will know.
8541Hawk Jun 27, 2009 02:26 AM
You just got too much water on the back of the gauges when you washed it.
Mine used to do the exact same thing, just be careful when you spray the water and even if it does happen again, it's no big deal as it will turn on again after it drys out and you cycle the ignition switch,
skoshere Jun 27, 2009 07:04 AM
its the R/R. mine did the same thing as above, but went to a R1 unit and hasnt been a problem since
superman_006 Jun 27, 2009 07:29 AM
I did an r/r update about 2 months ago, the bike seems to be charging/starting better than ever.
Circuit_Burner Jun 27, 2009 12:50 PM
Maybe water.
Im engineering a R/R and stator tester that I can maybe sell for at least 30 bucks.
Should be a nice piece of test equipment for serious bike owners.
8541Hawk Jun 27, 2009 01:48 PM
Originally Posted by Circuit_Burner (Post 224341)
Maybe water.
Well I've owned a SH for almost 12 yrs now and the speedo shutting off because it got wet is a common thing.
Riff Jun 29, 2009 08:27 PM
no, no, no... it's the speed sensor found just below the rear cylinder
Riff Jun 30, 2009 05:46 AM
I should add that your symptoms are exactly what you will find when the speed sensor is on the way out, those bieng no reading on the speedo. and no progression on the odo.
The water theory is easy to eliminate, ride dry and if the problems persist...
