speed bleeders?
has any one tried speed bleeders? they are only 15$ or so seems much cheaper than a brake pump? just wondering before I buy
I used them on a previous bike and they work OK....
I use a Mity Vac now, and that works equally as well.... if you buy 3 speedbleeders... it equals the cost of a mighty vac.... plus you can use it on other items like the clutch and other bikes. J. |
the ones I looked at were a set, front rear and clutch for around 15$?
Even if you're not bleeding things often a MityVac is worth the money. Especially if you have five(cheap) vehicles to work on as I do. It'll pay for it in no time if you ever have to do your own brake or clutch work.
