SuperHawk Forum
-   -   Some white smoke @ idle (https://www.superhawkforum.com/forums/technical-discussion-28/some-white-smoke-%40-idle-11927/)
NakedSH Jun 24, 2007 10:44 AM
Anyone give me the skinny on causes of slight white smoke coming from the exhaust at idle. Usually white smoke is indicative of water being introduced in the system, right? :( Noticed this late afternoon yesterday during a 200 mile ride in 95 degree weather while sitting in traffic. Its a '98 SH with 24k miles. The temp gauge shows slightly more then half way when It will start to produce the whitish smoke, at a warm idle. It does not smoke at lower engine temps or at startup.
Ideas??
Hawkrider Jun 24, 2007 05:39 PM
Are you running antifreeze? If so then smell the exhaust. If it distinctly smells like antifreeze then it ain't good. If not then I wouldn't worry about it. Is it actual smoke or just steam? Steam goes away quickly. Smoke does not.
