So what tire Pressure is everyone running??
Unlike a useless oil thread, or even tire thread, I thought this might be a good one since most folks do bother check there tire pressure...:shock:
I run 34 in both right now...usually 32 front, 34 rear..... |
Because of the hot roads and long straights around here, I use max: 36/42 but once I finally get to the twisties I'll drop it down to 32/36.
(Post 58880)
(Post 58879)
So according to you two,,,If your doing a lot of flat tracking, the presure should be up...then when hitting the twisties, drop them back down?
Regardless of temps?? Pilot Powers... |
To your original question: Depends on your tires. =P
Canyons: I ran 34/34 for my Diablo Corsas. 36/36 for my Metzeler M1 Sportecs. Track: 32/31 for Diablo Corsas. 34/34 for Metzeler M1s. 32/32 for Dungflop 208GPAs. 33/18 for Michelin Power Race. The numbers may vary depending on ambient/track conditions, but typically not much father from those numbers. |
Originally Posted by marmaladeboy
(Post 58895)
Canyons: I ran 34/34 for my Diablo Corsas. 36/36 for my Metzeler M1 Sportecs. Track: 32/31 for Diablo Corsas. 34/34 for Metzeler M1s. 32/32 for Dungflop 208GPAs. 33/18 for Michelin Power Race. The numbers may vary depending on ambient/track conditions, but typically not much father from those numbers. But I am talking street...As I would imagine, they would differ quit a bit from track... |
Im in at 36-38 no luggage on longer straight rides/commuting and 37-40 with sattle bags or passenger.
32-32 when out on the twisties. Track... though not specifically requested here - oops 30-30+- on the track (Dunlops or Bridgestones). Pirelli Superbike or Supercorsa is whole other animal especially on the track where they like to be lower, 27-26 normally but my TL likes it at 27-28 or I cold tear the tire. |
(Post 58898)
I think I ran the Dunlops at or around 28-29 on the track (cold tire, warm day) and it performed great, and looked beautiful at the end of the day. I have no idea what to run on the street, but I think I set them up at what the manual recommends (or a little less) maybe 36 to 38.
36/42 It seems to handle better when fully inflated too. But I might just be psyching myself.
SH: Pirelli Diablo's, 30 front 25 rear.
Suzuki stunter: Bridgestone BT012's 25 front 20 rear |
Try using nitrogen, your temps will be substantially less critical, and the average joe can maintain an "always" pressure. Hit your local airstrip and just ask. Most won't charge a thing.
LB |
I like 3 lbs difference between front and rear. 33F/36R for commuting. 30F/33R for long twisty rides. Currently in Pirelli Diablos. Have used with 208s, M1s, and Pilot Roads. Edit... fyi .. I'm light at 167 lbs.
I was laughing when I saw this thread.. But since everyone else is taking it so serious, I will too...
Pilot powers front and rear... nearing the end of rear life and 4000+ miles (no lie), may be closer to 5k... I keep it around 30 in the rear.. 32 in front cold measured. Anything lees and the front shakes under braking. And FYI, I think I have around 500 miles left on rear tire... |
Originally Posted by lazn
(Post 58927)
street - i run 33/32 most of the time. on cold winter days or in the middle of summer i'll vary off that a bit.
track - depends a lot on which tire i'm running & track conditions. ( i go up & down depending on the feel of tire ) tim |
