Should I consider this...!!?
How much of this 2000 CBR 900 will bolt onto my 98' Hawk?
Wheels, forks swingarm etc? What would be the price that would make you jump on it? :-0) Thanks 2000 honda cbr |
Front end is mostly bolt on, swingarm doe's not fit, you can only use the brace potentially, I would say, if you can get it for $500 grab it, otherwise....
Originally Posted by NHSH
(Post 393134)
Originally Posted by 118811
(Post 393135)
So, I could switch the entire front end (including triples) onto the Hawk?
Or.....would the fork tubes, wheel & brake go into the Hawk triples?
That would be the easiest, right? |
(Post 393140)
That is a CBR929RR by the way, so if you do a search you can see what 929 parts bolt up.
You should be able to get it cheap, use the front end, and sell the other stuff off. It should be easy to sell the other stuff, which will make the front end free... James |
(Post 393142)
You should be able to get it cheap, use the front end, and sell the other stuff off. It should be easy to sell the other stuff, which will make the front end free... James That was my original thought, too!! BTW....the serial number plate in the listing shows 900RR....? Would that make a difference? |
No difference. The 900rr and the 929rr are very different machines.
It is a 929. James |
I believe the bearings are even the same. For that cheap I would buy it for a track bike.
You could sell the rest of the parts for good cash, motor, swingarm, tank, fairing. If you have the room and time to dismantle I would do it in a minute. |
(Post 393154)
You could sell the rest of the parts for good cash, motor, swingarm, tank, fairing. If you have the room and time to dismantle I would do it in a minute. Hopefully I will have gotten the SH up and running by then too! Unfortunately we don't have a track here on Oahu....so it would only be a parts bike for me. But if I can get it at the right price & cherry pick & sell the good bits & pieces, it will make sense. I don't have much room for storage....so there will be some waste. |
