Shift Peg went good bye!
So this morning riding down the highway I went to shift into 5th and found that my peg vanished and no longer resides on the shift lever. Nothing is broken but it looks like these little guys are screwed on instead of welded.
Anyone know where I can get a new Shift Peg that will fit even if its not oem? Local shops had nothing to offer except a bolt that i have set in with a washer with 2 nuts. Looks ghetto as hell and would like to find a new peg. Any assistance would be helpful. I have found like a billion harley pegs but im not trying to rock skullz and snake pegs. Thanks! |
Contact Jamie: SuperHawk Forum - View Profile: JamieDaugherty as it sounds like you might have one of his shifters on your bike.
Originally Posted by 8541Hawk
(Post 337420)
Contact Jamie: SuperHawk Forum - View Profile: JamieDaugherty as it sounds like you might have one of his shifter on your bike.
Is this something the PO would have done?!? Im not aware of a swap lol. Were the factory units welded on as opposed to bolted? |
The stock unit is cast as one piece. Though you could always post a picture....
(Post 337422)
This is true haha Ill go do that. Thanks. |
1 Attachment(s)
Does the one you have look like the one in this pic?
Attachment 14277 Also are there 2 mounting points for the the shifting peg and 2 mounting points for the shift rod? |
2 Attachment(s)
See attachments!
(Post 337424)
Attachment 14277 Also are there 2 mounting points for the the shifting peg and 2 mounting points for the shift rod? Yes on Both accounts according to my pictures. I guess its an upgrade then by jamie. |
Thatd definitely a jd shift lever... hes a good guy and extremely easy to deal with...
Originally Posted by maniac2313
(Post 337429)
I sent him a PM thanks guys for the insight and time! |
Actually mine is just like that & isnt a JD job. I know since I did it myself when I broke the orig. All you need is the rubber part right? Or is the whole bolt gone (then you need the bolt too)
For sure you could put any rubber on it but you could get this http://www.ebay.com/itm/SHIFT-PEDAL-...00b532&vxp=mtr |
(Post 337434)
For sure you could put any rubber on it but you could get this SHIFT PEDAL SHIFTER RUBBER ONLY | eBay |
Yeah, any hardware store, pretty standard. Besides the bolt will be covered, but this time be sure to get nylock nuts.
Originally Posted by kardiac996
(Post 337438)
the whole bolt is gone. Good Call on that link wouldn't happen to know where i can get a pretty bolt like they got pictured do you?
(Post 337444)
The one in the pic is not a bolt, it's part of the shifter..... One piece cast unit. ;)
haha.. well thank you both as i now have direction. Thank you again! |
shifter peg loss
I went with Jamie's shifter conversion and am very happy with it. I lost the shifter peg after a couple of weeks, but found it in my driveway. I put it back on, but didn't use any locktite or lock-washers and the peg came up missing again a couple of weeks later. I replaced it with a piece of aluminum rod that a friend drilled and tapped and knurled the O.D. It looks pretty good, but won't be as comfortable to use barefoot or wearing sandals.
Originally Posted by wolfgun
(Post 338738)
... but won't be as comfortable to use barefoot or wearing sandals.
