Dang pilot screw has me pulling out my hair!
Old 08-09-2007, 06:45 PM
redman's Avatar
Thumbs down Dang pilot screw has me pulling out my hair!
So I bought the 40dollar fancyass screwdriver from MotionPro, to adjust my pilot screws and find out they're goofy little D headed things and the MotionPro tool is a normal flat tip. How do you guys adjust those things? I had to scour the manual and use a dentists mirror just to find them.
redman is offline
Old 08-09-2007, 07:43 PM
superbling's Avatar
Pull the carbs and dremel a slot on them for the motion pro tool.
superbling is offline
Old 08-09-2007, 07:49 PM
redman's Avatar
Guess that's the only way......oh joy
redman is offline
Old 08-09-2007, 09:13 PM
WERA #44
happytrack44's Avatar
We did mine by using dental tweezers and a bucket of patience to get them out. I slotted them with a THIN dremel cutter wheel. Works great. Carbs gotta come off, but that's not bad on this bike.
happytrack44 is offline
Old 08-10-2007, 08:16 AM
redman's Avatar
LOLOL..had to laugh at that last statement. I'm used to old British bikes...the carbs are right there in your face and two nuts each gets'em off.
Oh well.....once I do it, it'll be done...and I have the fancy screw driver to adjust'em with forever.
redman is offline
Old 08-22-2007, 06:51 PM
IAGeezer's Avatar
IAGeezer is on a distinguished road
I can't help but jump in on this one - I tried to make a tool from 1/4" alum tube, flatten one side using needle nose screwdriver to do it. Tore hair out. Repeatedly. Not smart enough to steal dental tweezers, so I bent one side of a nail head-up(!), and it worked!
If you still have your Honda jets, etc in there, go to Radio Shack, get the assorted tiny washers for about 2 bucks, and shim your air needles(under the diaphragms) about .040. Be sure to measure the washers with the dial caliper you use when you resize your ammunition. (Hee Hee) The reason you want to do this now, is that way you won't have to take everything apart again and end up standing in a pool of gasoline (don't ask...).
Greg has explained this better than I ever could on other threads. Good luck!
Scott
IAGeezer is offline
Old 08-22-2007, 08:34 PM
cliby's Avatar
motion pro also sells an adapter for the Dshaped screw - comes with one of their right angle screw drivers.
cliby is offline
Fox
12-14-2010 11:46 AM
dieschem
02-04-2010 12:02 PM
redman
12-07-2007 05:23 PM
senecagreen
02-16-2006 04:06 PM
ClevelandSuperhawkRumble
03-28-2005 06:59 PM
Quick Reply: Dang pilot screw has me pulling out my hair!
